I have an LG the picture is solarized. The original problem was the red light not responsive to the power button so I replaced the main board. The tv turned on but the picture is polarized. Already replaced the t-con with no change.
55LB6000 solarize picture
If the solarization on your panel is the same with your original TCON and also your new TCON, I would suspect the panel, or the LVDS cable (from TCON to Mainboard), or the mainboard itself.
LVDS problem could be 1) bad or damaged cable itself, or 2) not properly inserted at one end or the other, or 3) oxidation or dirty pins at either end male of female connectors.
If you had nice clear image on your screen before replacing your mainboard, your panel is probably ok. It is possible you damaged the LVDS cable in your repair. Check that.
Also, Are you absolutely certain the mainboard you bought is for your specific model number? Some mainboards may look exactly the same but are programmed with a different firmware. For example, if you have a 55" TV, but your mainboard is from a 50" TV, there could be differences.
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by CyberPhoenixHello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
- Loading...
