Samsung UN43NU6950FXZA No power
  • mrtek
    • Oct 2010
    • 65
    Hi
    Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
    Main fuse = OK
    Back light LED = OK. Power them with aux power source
    LED output = OK 156V
    I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
    Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on when power button is pressed. The power button signal goes from HI voltage of .445 V to a LOW voltage of .124 V. The switch is not stuck in one position.
    This TV has only one PCB wich includes power supply, main and t-con.
    Wondering if anybody has a schematic or experience with this kind of board.
ID:	3687034 Click image for larger version
ID:	3687035 Click image for larger version
    Thank you in advance for any advice / info.
    Massimo
  • mrtek
    • Oct 2010
    • 65
    After trying to troubleshooting this PCB, I have purchased another one. TV is up and running.
    Massimo
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4506
      • Italy - Milan
      You probably need to reprogram the standby eprom flash that is near the quartz (ic503? ic583?)
        by sam_sam_sam
        03-31-2024, 02:12 PM
        by sam_sam_sam
        07-01-2024, 06:34 AM
      • cheeky2
        Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
        by cheeky2
        This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
        I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
        Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
        06-15-2025, 05:12 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
