Hi all I'm after some advice I have a hitachi P50x01AU no picture. Turns on led at front red goes to green. Do I need an input signal to get a picture ? I have replaced the two 3300uf 100v caps(bulged) in the upper right hand side of the power board , measured the Vs and Va at CN99 as per the sm, 3V on Vs and 0V on Va, so I ordered a new power supply but after reading some posts on this site I may have made an error any ideas thanks.
hitachi P50x01AU no Picture
by KYBOSHPicked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
No picture but you hear the TV static (white noise) playing loud and clear.
The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
But it seems they didn't get too far and just left it.
When I first took a look I was amazed at how pristine the inside looked.
Its as if the TV had been in a time capsule.
Caps looked like they were just pulled off the self.
Copper coils had no sign of corrosion on... -
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by JackUziHi all,
First post so please bear with
So I found a similar issue on another thread but have been advised to open a new one so here it is.
One day this TV started doing this:
https://www.youtube.com/watch?v=42QlTOSOCjw
This happens on all inputs and menu screens.
Thank you to nomoresonys for previous advice - to check voltage on powerboard connector and possible loose/bad tab bond.
I've opened it up and tried reseating all the ribbon connections but the problem remains. I need some support in testing...2 Photos - Loading...
