Sony KD-75X750H no backlights
  • x_orange90_x
    • May 2015
    • 753
    I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
    Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and no backlights. Since people say they replaced them and it still did not work, hunting at a power supply issue.
    • 12307
    • U.S.
    With the flash and the difference in your readings, it's probably a bad backlight or two or three...
    • howardc64
      • Jun 2017
      • 653
      Google led strips shows each string is 4 bars x 13 LEDs. 4x13x2.7v/LED=140V assuming both strings have same # LEDs.
      Whenever I’ve had LED readings different from the calculated string voltage. Failure has been LEDs.
      I’m guessing your PSU shut off backlights when detecting it was out of range.
      You could try the following for more definitive confirmation but probably really hard. Need more hands or secure led tester to light string hands free.
      with led tester connected to 1 string for backlight. Run a white screen test on YouTube. Can see failed LEDs easily. An external streaming stick already running white screen test might make it easier.
      • x_orange90_x
        • May 2015
        • 753
        I may try this. The most difficult part isn't really securing the tester leads into the plug, it's maneuvering this thing. I had my wife help me lay it down on the table and she was struggling to get it up high enough. Diagnostics would be much easier if they didn't require you to remove the feet in order to get the back cover off.. That is purely unnecessary.
        I'm pretty confident that it's bad LEDs causing this. The voltage difference would suggest that an entire strip is out, likely due to a single bad LED 🙄
        • howardc64
          • Jun 2017
          • 653
          I usually put tv on bed /carpet upside down (often the fragile buffer boards / flex is exposed during diagnostics ) then not too hard to hold it vertically or lean against the wall. makes navigating menu a little difficult
            • 12307
            • U.S.
            For the big ones it would be nice to have one of those big slanted stands for working on them, very costly but have seen some diy ones made of wood that look very useful. Specially when you need to see the display and such while trying to work on those monsters.
            • x_orange90_x
              • May 2015
              • 753
              I just got it apart tonight. There are 8 bad LEDs. I Will order a new set and update this thread after I get it back together. Thanks for the help guys!
              • Pipolups
                Corsair K70 LUX RGB dying LEDs
                by Pipolups
                Hi there !
                I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                10-08-2024, 11:58 AM
                Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 05:27 AM
              • gkolio
                Sony Bravia 55w905a - 4 Red LEDs Blinking then Pink Tint
                by gkolio
                Hi have problem with 4 reds blink take lot help that forum and tell me change led strips and all going very good tv alive now but in down left have pink tint little and see only in white pages what wrong doing?
                12-01-2023, 09:09 PM
              • notallbad
                Samsung UE50TU7000K backlights on, no picture or sound
                by notallbad
                Plug in and backlights with Smart Tv powered by Tizen logo shows on screen
                then nothing, no stby led or response to remote, no sound from hdmi input.
                This has only 1 board, a 3in1_kant_su2.
                Try a usb stick with update firmware from Samsung and usb stick just flashes a couple of times, recognises usb, but thats it.
                Remove ribbon to panel, same results.
                I believe the leds are in an array of 3 x 12 @3v/led, going by what led sets are being sold for this tv on ebay and aliexpress.
                1 string of 12 leds, power supply in 84v, out...
                12-02-2022, 08:55 AM
                Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                09-06-2024, 05:30 AM
