Samsung LE32R88BDX no picture but sound.
    So as above, the back light comes on, T-con tested fine in another Tv yet I have no picture, everything works so it has sound, will select different sources, seems to react to the menu as the back light will brighten up yet I still have no picture, I do hear a slight funny noise which seems to be coming from the main board but after it's warmed up it goes, any ideas on what this issue is? thanks, Andy.
    Re: Samsung LE32R88BDX no picture but sound.
    Check AVDD&3.3V on T-con board - if they drop on this panel could be a bad panel. Also check if T-con is getting 12V at fuse. Have to say I have never seen a bad panel on these.
      Thankfully I have a spare panel so swapping over is no problem, I'll give the fuse a check later. I did read that the PSU could be at fault, I can't really see that being the case but is it a possibility?
        If PSU voltages are OK I would say that is not a problem.
          I see this in archive.
          https://www.badcaps.net/forum/showthread.php?t=30654
            Thanks for that but have already found it, good info though. So the PSU voltages prove fine so I had a good look at the main board and found IC1108(on the underside very near the LVDS connector) had a nice big crater in the middle of it, quite obvious really so I shall be changing it over from a spare board, fingers crossed I do a good job and that it works, thanks.
              Said IC changed and Tv now works, thanks.
                Hello, I have the same issue in my TV, could you tell me which is the IC1108?, because I can“t see in my burned IC.
                Thanks.
                  Lucky for you I have another bad board with this chip, the numbers I see are:
                  4435B
                  BG
                  L74A
                  When searching, the first five digits will give you instant results, I hope you get it working, Andy.
                    4435B
                    BG
                    L74A
                    Thanks a lot,
                    I'll try to buy, and then I will change it.
