i hoped too to have it, it I don’t have it s one board only…..one board for the right side one bioard the left I give u the photo. I give u the photo also of the pack of resistors, how u can see the pack on the extreme right is a little brown do to the hot temperature, the left side also have the same pack of resistors they become hot but a little less, and u can see they aren’t brown. Really thanks for your help
LG 55uh661v flickering images and lines
by reessiHello,
The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
They are black on the right and gradually fade to nothing on the far left.
They start either after 5 mins or up to 2 hours after so annoying for testing.
They flicker continuously very fast! With a slight pause milli-second every second.
Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
I tested each half by removing the first the left flex from...-
by GuybrushAfter watching too many electronics repair videos (but not monitors) I came across a dell monitor with flickering horizontal lines. I haven't purchased it yet so don't have much info, but from the video and pic do you think there is a chance of repair or is just simple panel damage?
Seller claims; "but due to sun damage has some grey lines going through it"
https://i.imgur.com/VpTcZFn.mp4
Chris...-
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by mrsithHello again good souls.
Got an UE70TU7100. The TV starts up just fine, but right hand side of the screen is horizontal striped a bit, and there are some flickering horizontal lines on the whole length of the screen. I've seen similar static horizontal lines sometimes, when applying the cut tape method and covering wrong number of pins.
I've cleaned every connector with ipa, tried cut tape method on main LVDS ribbon as well as small ribbons, connecting the panel boards at the bottom. Tried squeezing the bezel and playing around COFs, but no reaction at all. COFs and... -
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
- Loading...
