LG 55uh661v flickering images and lines
  • arctor
    • Mar 2025
    • 21
    • italy
    Originally posted by Diah
    still the downside of the boards you didnt posted photo of it,
    under the speaker of the side which you wrote become hot, you have U ribbon cable on the buffer boards, disconnected and see if you have 3/4 stable picture
    i hoped too to have it, it I don’t have it s one board only…..one board for the right side one bioard the left I give u the photo. I give u the photo also of the pack of resistors, how u can see the pack on the extreme right is a little brown do to the hot temperature, the left side also have the same pack of resistors they become hot but a little less, and u can see they aren’t brown. Really thanks for your help
    • arctor
      • Mar 2025
      • 21
      • italy
      • reessi
        ACER BM320 Monitor - Horizonal Flickering Lines After a While
        by reessi
        The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
        They are black on the right and gradually fade to nothing on the far left.
        They start either after 5 mins or up to 2 hours after so annoying for testing.
        They flicker continuously very fast! With a slight pause milli-second every second.
        Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
        I tested each half by removing the first the left flex from...
        06-03-2025, 09:58 AM
      • Guybrush
        Dell U3419W horizontal lines and flickering
        by Guybrush
        After watching too many electronics repair videos (but not monitors) I came across a dell monitor with flickering horizontal lines. I haven't purchased it yet so don't have much info, but from the video and pic do you think there is a chance of repair or is just simple panel damage?
        Seller claims; "but due to sun damage has some grey lines going through it"
        https://i.imgur.com/VpTcZFn.mp4
        Chris...
        10-23-2023, 06:17 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • mrsith
        Samsung UE70TU7100 - flickering horizontal lines
        by mrsith
        Hello again good souls.
        Got an UE70TU7100. The TV starts up just fine, but right hand side of the screen is horizontal striped a bit, and there are some flickering horizontal lines on the whole length of the screen. I've seen similar static horizontal lines sometimes, when applying the cut tape method and covering wrong number of pins.
        I've cleaned every connector with ipa, tried cut tape method on main LVDS ribbon as well as small ribbons, connecting the panel boards at the bottom. Tried squeezing the bezel and playing around COFs, but no reaction at all. COFs and...
        02-13-2023, 05:36 AM
      • Stanley1843
        by Stanley1843
        06-29-2024, 11:54 AM
