75uq7590pub Has backlight no image
  • ShatterMasters
    • Oct 2017
    • 14
    I have a 75uq7590pub that was dropped off for recycling. The Tv powers on and has audio but no picture, the backlights are working. Here is what I have attempted so far. Replaced main board, tried connecting one ribbon at time and testing. Not sure where to go from here. Any ideas?
    Thanks!!
  • EazyBone
    • Jun 2023
    • 1321
    • United states
    Lookup fixing TV with tape. See if you can get a picture that way.
    But also try to disconnect one of the ribbons on the buffer boards that is orange/transparent at a time also. See if that does anything first.
    Its no unheard of to get a bad main board, but if both boards have sound and no picture I would start checking the panel
    • ShatterMasters
      • Oct 2017
      • 14
      I have tried the tape trick on some other models.
      Tried un hooking the ribbons on the LCD flex with no change.
      I was not the person who ordered the mainboard, I am having little luck finding the same tv version mainboard. Id assume that is important?
      Thanks!
      • EazyBone
        • Jun 2023
        • 1321
        • United states
        Ah okay, then it's possible to suspect the main also. Do you have both main boards? Do they both do the same thing? What's the EBT numbers on both
        Tape trick will not always show a panel short, but it's semi reliable.
        • Storyteller12
          • Jun 2020
          • 624
          I've fixed a few of these TVs in the 55 and 65" models with same problem. Seems the buffer board from the panel gets shorted out to the frame somehow. I removed the buffer board and put electrical tape where
          the buffer boards contact any metal and problem fixed.
          be careful not to rip/ tear one of the cofs.
          Hope you have the same problem so it's an easy fix.
          good luck, let's us know
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
          • Salem Aboshala
            820-00138-A got image but no backlight
            by Salem Aboshala
            Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
            I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
            History: my laptop backlight stopped working without any reason.
            Symptoms:
            I have image on screen using my flashlight.
            I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
            Keyboard backlight still working and can be adjusted normally.
            Since two days I tried to follow all similar...
            06-11-2024, 03:02 PM
