lg 50ps3000 no picture
  • thuss
    • Jul 2012
    • 317
    • uk
    Hi
    My 50ps3000 has got no picture. the led flashes blue approximately 6 times then stays on for about 20 seconds and then turns to red again.
    I have opened the back and checked the voltages (va vs)and there is seems to be no voltages going to the y sus and the z sus.
    The voltages going to the av board from the power supply are not what they should be.
    all the fuses seem fine and all the caps seem fine, The power supply part number is EAY60716801
    One fuse near the large filter caps takes a while to beep but when I turn the range up on the multimeter I do get a reading I assume its due to the 450v filter capacitors next to it?
    Any help would be appreciated- thanks
    Re: lg 50ps3000 no picture
    Pull Z-sustain power and see if you get a dim red picture.
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      One fuse near main caps takes a while to beep on your meter? That doesn't sound right.
      Can you recheck that fuse? Should read the same as if you hold probes from meter together on 200ohm scale. Like 0.2 or 0.3. If its reading some higher and slowly dropping, that means fuse is bad and all you are measuring is a cap in the circuit.
      Unless its not a fuse your measuring?
      Definitely follow Tom66 instructions,you got a skilled member on your side with him ,just thought the fuse reading was strange...
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • thuss
        • Jul 2012
        • 317
        • uk
        Unfortunately there was no difference when I disconnected one board at a time.
        So I removed the fuse in question (f801) and you were right it was blown plus a couple of mosfets and diodes were also blown all the resistors seem fine.
        So I looked on the internet for a repair kit which includes replacing a ic- do you think I would need to change the ic( I cant tell if its blown or not)?
        Thanks for your help
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          That ic is a driver for or of the mosfets. You probably will have to change that yes.
          I wouldn't know how to test it, you can try and find the specs of that IC and measure from the ground pin to the drain and vcc to make sure.
          Any numbers on that ic?
          • thuss
            • Jul 2012
            • 317
            • uk
            the ic has the following numbers on it l6599D, 900D925 I will have a look at the datasheet and see if I can measure from the ground pin to drain thanks
            • thuss
              • Jul 2012
              • 317
              • uk
              had a look at the datasheet would pin 9 the pfc+stop be the drain?
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                Don't have the data sheet here,can you post it?
                • thuss
                  • Jul 2012
                  • 317
                  • uk
                  sorry about the late response -it was the ic so thanks for your help
                  • maneatingmonkey
                    Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                    by maneatingmonkey
                    I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                    There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                    03-27-2024, 07:17 AM
                  • corrize
                    A funny fuse story – Lumix LX100 II
                    by corrize
                    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                    10-19-2023, 09:58 AM
                  • Tr0ll
                    by Tr0ll
                    Original T-con:
                    First replacement T-con:
                    10-07-2023, 07:48 PM
                  • JJAAMM
                    by JJAAMM
                    Problem
                    07-06-2023, 06:01 AM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
