Need bios file Hikvision DS-7608NI-Q1/8P
  • Carlito Jr. Tiopan
    • Apr 2025
    • 10
    • PHILIPPINES
    somehow the nvr got bricked and the powersupply is not working only power indicator and no display . badly need a bios dump file for
    Model: DS-7608NI-Q1/8P
    Serial: C61546345
  • Fr33man
    BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
    by Fr33man
    I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
    *Novo button power on
    *Disconnected internal battery...
    09-23-2024, 01:16 PM
  • studdy05
    Bricked HP Probook 450 G7 Bios questions
    by studdy05
    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
    Ive got...
    07-08-2025, 09:24 PM
  • pcwhiz24
    Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
    by pcwhiz24
    Model: Lenovo IdeaPad 3 14ADA05 81W0
    S/N: PF2BZS7D
    I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
    I already have a CH341A programmer...
    04-07-2025, 07:10 PM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • m1ch43lzm
    by m1ch43lzm
    Hi everyone
    09-06-2025, 05:47 PM
