Vizio SV422XVT problem only coax input works
  • doomstriker
    • Jul 2014
    • US
    I'm having a problem with my 42" Vizio TV. I hooked my tablet to the HDMI inputs eveything was fine until the screen went black and now the only input that works on the TV is coax. No hdmi, no component, no rca. I tried hooking up a laptop to the Hdmi port and the computer
    detected the TV model but no image.
    Any ideas, what could be the problem?
    Thanks,
    Wil
  • derrickcaputo
    Issue with 42 Vizio TV
    by derrickcaputo
    I have a 42" Vizio TV. I hooked my tablet to the HDMI inputs. Everything was fine until the screen went black and now the only input that works on the TV is coax. No hdmi, no component, no rca. I tried hooking up a laptop to the Hdmi port and the computer
    Is there anyone having the same issue? Did you find any solution?
    08-20-2024, 12:21 AM
  • pdsterns
    Vizio 42" M420SL works then goes blank
    by pdsterns
    Good Morning TV'ers
    Vizio usually starts and works fine for a few minutes then goes blank. Checking voltages when shutdown it reads 5v on the standby pins on the PS and 12v on the 12v pina, backlights are out now. What can I conclude or where to next.
    Thanks in advance
    burns
    12-12-2022, 08:34 AM
  • SS454
    vizio e650i-a2 backlight flashes then turns off
    by SS454
    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
    panel: au optronics T650HVN05.4
    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
    https://www.shopjimmy.com/vizio-56-0...-power-supply/
    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
    08-20-2020, 03:57 PM
  • mrtek
    Vizio M65-C1
    by mrtek
    Hi.
    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
    07-14-2025, 07:28 PM
