samsung PN43D450A2D relay clicking no sound no picture
  • jose6326
    • May 2013
    • 707
    Re: samsung PN43D450A2D relay clicking no sound no picture
    I really hope it didn't take out the ymain
    • jose6326
      • May 2013
      • 707
      So I got the xmain board in
      Before I power it up should I look out for anything or test anything?
      Also where/how do I update the firmware?
        You should check ALL of the IGBTs/FETs on the Y-main.
        You should also check Y-buffer for shorts to output.
        • Shinju
          • Mar 2014
          • 1239
          http://www.samsung.com/us/support/ow...PN43D450A2DXZA
          Also this unit is a fragile beast, I just repaired one with the exact same xmain fault.
          Also make sure your panel voltages are with in spec or you will have this failure again.
          To verify y-main stability run the scollingbar panel wash and see if you get any strange colors in your extreme whites.
          Good luck!
          • jose6326
            • May 2013
            • 707
            Tom how do I check for shorts to output on the y buffer?
            Shinju im guessing I check panel voltages with everything connected after I have tested the y main components?
            How do I run the sidedcrolling?
            • Shinju
              • Mar 2014
              • 1239
              It's under the picture options/ anti burn in options/ scrolling bar.
              • jose6326
                • May 2013
                • 707
                Thanks I will try that after I test the fets on the y main
                  Test Y-buffer: https://www.youtube.com/watch?v=51SZ...Y&noredirect=1
                  • jose6326
                    • May 2013
                    • 707
                    Ok just wanted to give an update
                    I installed the xmain board
                    The tv powered on with no issues
                    Pictures looks good
                    Va, vs and vsc voltages are all within spec
                    They were off about .5v-1v
                    I did NOT update the firmware. Should I?
                    Also I have not performed the scrolling bar function. Should I?
                    Thanks for all the help
                    • capkid
                      • Oct 2010
                      • 1339
                      Pictures looks good
                      Firmware update: Yes.
                      LG Plasma Mal-Discharge Correction Service
                        09-07-2024, 05:50 AM
                      • Journey11
                        Samsung TV won't turn on ... keeps cycling the power relay on & off
                        by Journey11
                        Hi All,
                        First time posting here ... my name is Kevin but my friends call me Journey.
                        I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                        After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                        It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                        07-04-2024, 02:44 PM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
