Samsung innards. Replaced bad cap and blown pico fuse on x main, still no picture, but we have audio. Suggestions
Sanyo dp50747 Chassis 03 Audio no picture
Tags: None
Re: Sanyo dp50747 Chassis 03 Audio no picture
Vs...207v
Va...55v
Vg...15v
Ve...100v
Symptom is no picture with audio. I have a multimeter. -
Here is a manual. Pay attention to page 5 for the power failure circuit that is on the main board. Pages 29 and 30 also have good info. Pages 42 and 42 have flow charts. they have complete parts listing for boards too.Attached Filesif you find these attachements useful please consider making a small donation to the site
Is there a panel reset sequence? How can I select it if so? Panel still not coming on but I have audio. I also do not have a remote for the set so I do not know what input is selected if one.Comment
maybe read this and see if this applies to your TV?
http://blog.coppelltvrepair.com/2014...epair-for.htmlComment
Exactly, what I saw and i replaced those components. I still am not getting a picture on the panel. I don't have a remote so how to bring up a menu when I can see anything would be the next thing. I plug the set up turn it on and then I hear the static sound. I plugged the hdmi cable in but can't go to menu to select hdmi port since I can't see it.Comment
What is a good test to confirm panel is bad on this unit?Comment
The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
The player processes the audio signal using two different reference frequencies. The "R"...2 Photos -
by IAmOrionHi members, I came across this forum when searching a fault on my LG 55UB850V TV.
Rather than hi-jack another members post/thread I thought I should start my own even though it's an almost identical issue.
The thread I refer to can be found here:
https://www.badcaps.net/forum/troubl...-s-help-please
My boards are the same, and my issue it the same. I have NO Picture and NO Sound. Nothing. When first turning on the TV at the... -
My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
Is there someone having any symptom like this? How to fix it?
Thanks in advance!08-06-2024, 09:55 PM -
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... - Loading...
