LG 55EG960V artifact
  • Bobby B
    • Apr 2025
    • 15
    • france
    Someone gave me that old TV, with few artifacts on the far sides and I didn't mind. However the places of the artifacts are changing when I turn the TV on and off.
    Any chance this could be fixable?
  • Diah
    • Feb 2013
    • 6541
    this is pixel refresh issue
    1- reset after cleaning 2 LVDS and ribbon cables from both side., ( DONT SWAP ribbon cables places or direction )
    2- send with service remote IN_STOP
    • Bobby B
      • Apr 2025
      • 15
      • france
      Thank you very much for your suggestions
      I tried both but they didn't work. I have a new patern that appeared (before I tried anything, so it's not my fault 😅 )
      If you have any other idea, I would be very grateful 😃
      Click image for larger version  Name:	7de7nUf.jpg Views:	0 Size:	1.15 MB ID:	3615793 Click image for larger version
      • Diah
        • Feb 2013
        • 6541
        send IN_START menu then go to OLED option post photo of yours screen keys
        • Bobby B
          • Apr 2025
          • 15
          • france
          Thanks for trying to help, but it no longer starts (I only have a little electric noise then it powers down). I broke it trying to clean the ribbons.
          • Bobby B
            • Apr 2025
            • 15
            • france
            I changed the ribbons and it's turning on again! The artifacts are still here however.
            Here is what I see in the OLED menu, I am not sure if this what you asked for.Click image for larger version
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4532
              • Italy - Milan
              Hi, you need to perform the screen test to see wether is a main board fault (example ram fault) or tcon fault (again ram fault/emmc fault), try to select 8. Test Option and see what it proposes.. depends on test result you can press down the aboves to see what changes, it can even be the main cpu or tcon cpu.. last of the checks is on the el.capacitors from the power board to the rest, especially tcon..
              • Diah
                • Feb 2013
                • 6541
                Here is what I see in the OLED menu, I am not sure if this what you asked for.Click image for larger version  Name:	20250915_225134.jpg Views:	0 Size:	1.80 MB ID:	3725775
                use it as its... time to time do Pixel Refresh , you can count how many time it did via e_Z Adj menu
                • Bobby B
                  • Apr 2025
                  • 15
                  • france
                  There are 2 options to update some firmware.
                  There is also a Soc test. It runs 10-15 min, then the tv turns off by herself.
                  Not a good sign I guess.
                  • Bobby B
                    • Apr 2025
                    • 15
                    • france
                    It will probably finishes like that. I don't the material or the knowledge to repair a card.
                    Note that I still haven't found where to do a pixel refresh.
                    • Bobby B
                      • Apr 2025
                      • 15
                      • france
                      Correction from my previous post : The TV just go to sleep for inactivity. I put some music on the TV to prevent that, and the test will run more than 1 hour without doing anything. Click image for larger version
Name:	WhatsApp Image 2025-09-16 à 10.32.07_f6d4f90c.jpg
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4532
                        • Italy - Milan
                        If you haven't knowledge BETTER ASK before doing anything in Service Menu, now show me "13. OLED" menu, we are searching for a "Post FRC test" or the like..
                        about the pixel refresh as someone call it or Screen calibration is a self running task, i do not remember but i think it is performed after 2 hours of constant TV turn on, i have to check at home some manuals.. or you can search LG oled discussions here last 1 year.. I guess your donor have runned it long to consider it faulty, so do not expect much it will restore itself.. for the few i know.. the SoC test good is a good news, maybe you'll end buying a less expensive T-con
                        • Bobby B
                          • Apr 2025
                          • 15
                          • france
                          I took a picture of each menu. I did not see anything that looks like FRC.
                          I left the TV on for a couple of hours (without any changes) but when I turned it back on, some artefacts had dissappeared and some new ones had appeared. Maybe the pixel refresh was triggered and did something.
ID:	3726502 Click image for larger version
ID:	3726503 Click image for larger version
ID:	3726505 Click image for larger version
ID:	3726506 Click image for larger version
ID:	3726507 Click image for larger version
ID:	3726518 Click image for larger version
ID:	3726508 Click image for larger version
ID:	3726509 Click image for larger version
ID:	3726510 Click image for larger version
ID:	3726511 Click image for larger version
ID:	3726512 Click image for larger version
ID:	3726513 Click image for larger version
ID:	3726514 Click image for larger version
ID:	3726515 Click image for larger version
ID:	3726516 Click image for larger version
ID:	3726517 Click image for larger version
                          • Diah
                            • Feb 2013
                            • 6541
                            we have in this forum same model threats where we solved it, so you have 2 option
                            1- as my early post #8
                            2- downgrade the firmware to low version... then upgrade it to last version.., as this set not belong to you... they may changed boards on it.... with this action will be the firmware of MB / MICOM/ and T-CON driver boards same parameter version. search here i did wrote how to downgrade and where to download all LG firmware versions
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4532
                              • Italy - Milan
                              There aren't video tests at all there, in this Samsung is way better... no one had rich menu like Samsung, or there is another menu, try to enter EZ-adjust menu and search for video test
                              • Diah
                                • Feb 2013
                                • 6541
                                i am laughing out , this very easy approve you have never put yours hand on OLED... its digitalis currents. from LG adjusted.. again this is OLED NOT LCD
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4532
                                  • Italy - Milan
                                  Bobby do not listen to that poor element, their messages are incomprehensible
                                  I saw this image from the internet.. as you can see probably the item Test Patttern like Samsung can lead to screen.test patterns.. plesse ignore that Deutch sir
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4532
                                    • Italy - Milan
                                    This from a video... the test is very poor, not as Samsung service mode, we don't see if is a pre FRC, post FRC and so on..
                                    if only full colors with no graphics then probably are TCON generated, and this is what we need)
                                    Try to cycle "Pattern Type" otpions and show me..
                                    Click image for larger version  Name:	Badcaps-1.jpg Views:	0 Size:	22.9 KB ID:	3726746
                                    • Diah
                                      • Feb 2013
                                      • 6541
                                      why you keep insist to harm others... the owner posted at post #13 photos of the INSTART menu... one of them show the point ( Adjust Check ---- and the Value of ( Adjust White Balance = OK (0) and the Value of Adjust ADC (OTP) OK )
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4532
                                        • Italy - Milan
                                        Don't break the balls useless man.. Learn to read...
                                        • N3Star
                                          Retro 8800 GTX from EVGA artifacts
                                          by N3Star
                                          I need help identyfing what is broken on this GPU - GPU core or VRAM. Let's start with what I did and know so far:
                                          - disassembled, added missing SMD capacitors from same GPU
                                          -(If anybody knows what Q518 is and would share this information I would be very grateful)
                                          - artifacts during Windows booting are blue vertical stripes, I can take a photo if that would help
                                          - artifacts in Windows are yellow-ish horizontal lines
                                          - in BIOS/ text on black screen text gets extremely garbled
                                          - GPU-Z doesn't show GPU or VRAM frequency
                                          - GPU error 43...
                                          06-14-2022, 03:45 AM
                                        • klugec
                                          KVA2 RTX 2060 Super 8GB Desktop artifacts
                                          by klugec
                                          Hello (sorry for my bad English),
                                          I have a strange problem with my KVA2 RTX 2060 Super. As soon as Windows 11 is loaded, artifacts appear. Now the crazy thing: When I start Furmark the artifacts are gone and Furmark runs great without crashing. Mats test shows me no errors (PASS). Drivers can also be loaded without any problems.
                                          Mods shows me the following error:
                                          Code:
                                          MODS start: Thu Feb  1 19:16:00 2024
                                          Command Line : gputest.js -oqa -old_gold -test 94 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -fan_speed 70 -matsinfo
                                          02-01-2024, 10:58 PM
                                        • HelpMeRepair
                                          6800XT artifact on benchmark and crash
                                          by HelpMeRepair
                                          Hi guys , thanks for the help and hint in advance
                                          I have a 6800XT that is detected , but im not able to memtest it ( says it cant buffer )
                                          if i try to benchmark it , it goes artifact and crash after few seconds.
                                          anyone have a clue ? thanks !
                                          card is a AMD FE 6800XT , and any hardware mem guide checkup can help if you have any tuto too !😀
                                          edit : component looks good after visual inspection .
                                          11-05-2024, 09:41 AM
                                        • madcrow
                                          Tearing-like display artifacts on Philips BDM4065UC
                                          by madcrow
                                          Hi There,
                                          Anyone familiar with this kind of display artifact?
                                          Gallery: https://imgur.com/a/tYc2dWK
                                          At a superficial glance, it sort of looks like screen-tearing. But that square-wavy boundary is weird...
                                          The phenomenon was detected on
                                          • 3 screen <=> PC combos consisting of
                                          • 2 different screens (same model: Philips BDM4065UC)
                                          • driven by 2 different PCs via
                                          • 2 different Nvidia GPU models (one desktop, one mobile) multiple generations apart,
                                          • running on 3 different Nvidia drivers, each with siginficant age-gap,
                                          • under Win10 Pro 22H2.
                                          Connections...
                                          10-26-2024, 01:38 AM
                                        • rattlesnake
                                          AT PSU produces video artifacts
                                          by rattlesnake
                                          I recently put together a retro build that uses a particular AT PSU that fits in this case (LPX).
                                          The model is HPN-100. I'm attaching pictures.
                                          The issue is that after a few seconds of being on, I start to get strange artifacts. The image looks wavy. First it's fine and then it starts to pick up. After about 60 seconds it looks like this:
                                          Does anybody know what kind of failure this is?
                                          Can the caps be faulty? Which ones should I put more emphasis on?
                                          What's the potentiometer for? What else should I check?
                                          08-19-2024, 11:11 PM
