Toshiba LCD 40RV525R HDMI Issue
  • Prop1
    • Jun 2014
    • 93
    As some of you know; I successfully fixed a Panasonic plasma TV recently. I let my son talk me into trading it for his Toshiba. We needed a new TV for the bedroom as our old Toshiba recently has developed dead pixels that have joined together into a pea size blob. The plasma was too heavy for the wall hanger, anyways.
    So, his TV looks great and plays fine. However, since converting over to DirecTV; the remote doesn't turn the TV on and off unless the slider is in the TV position. Also, the TV must be on first with the blue blocked "No Signal" showing or it doesn't see any video input on the HDMI when the box is turned on. It never did it with a Comcast or Dish box.
    Anybody ever experience something like that? Is it something that could be fixed in the service menu?
  • Prop1
    • Jun 2014
    • 93
    Re: Toshiba LCD 40RV525R HDMI Issue
    Update.
    Tried various configurations of the Regza feature with the DirecTV box HDMI Control ON and OFF. Made no difference.
    I suspect this is a software issue. I know there is a newer firmware version, but it's not on the Toshiba US site. It can only be found on the Canada site. I wouldn't what to update it with incompatible firmware and muck it up worse.
    May just have to live with it.
    • Prop1
      • Jun 2014
      • 93
      Problem solved. Not to my liking. Found this on satelliteguys.com:
      There are certain toshiba regza models that are not compatible with any of the directv white remotes. Reason is the extra signal added to the commands coming from the white directv remotes, this extra signal makes the toshiba commands unrecognizable to the regza models. This signal CAN"T be turned off, and any new white directv remote will have this problem too.
      If you were to do a code search you would come up with many working codes, but once the code is locked in the extra signal returns and it won't control the toshiba anymore. The white remote haven't changed, they always had this extra signal, what did change was the toshiba tv's became extra sensitive to the commands it accepts.
      • aliougm
        Marantz SR4003 AVR HDMI board issue, seeking for help
        by aliougm
        I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
        Connection as below:
        Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
        If I bypassed AVR then HDTV screen color be good.
        I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
        3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
        I replaced all...
        04-30-2022, 12:21 PM
      • spleenharvester
        Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
        by spleenharvester
        I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
        I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
        03-12-2025, 03:42 PM
        09-06-2024, 05:27 AM
      • ResetReality
        Toshiba/Vestel 58UL2B63DB Wifi Issue???
        by ResetReality
        Hello fellow tech heads.
        Had this tv come in...issue stated reboots on wifi.
        Indeed it does. However, with wifi off or using cat 5 cable no reboot issues.
        So far ive changed mainboard and wifi module...also reset tv back to factory via service menu (4725)
        Still same issue... i do have a psu to swap but cant see it being that really as works flawless if wifi is disabled
        I thought fireware? But why only on wifi?
        Is it an issue with the memory cache filling up and having to reboot for more ram??
        At a total...
        07-04-2024, 12:28 PM
      • ratdude747
        Intel HDMI Windows 10 issue
        by ratdude747
        Got my butt kicked by windows 10 and intel last week.
        I have an HDMI switch and splitter setup for an AV rig (church) that I was trying to use the windows 10 half of my Lenovo T440s with. However, the audio will not work; HDMI (displayport) audio doesn't show in device manager and Intel's Control Center shows the external display as not supporting audio. Direct connect it to things and (if memory serves) it does work.
        Compounding the issue is that I'm forced to use Lenovo's drivers... as the generic intel ones refuse to install as they detect it's a lenovo system...
        12-04-2022, 07:34 AM
