Emerson hdtv troubleshooting
  • ddarn
    • Jun 2014
    • 76
    Re: Emerson hdtv troubleshooting
    is that pic ok?
    • ddarn
      • Jun 2014
      • 76
      bump
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        #83
        sorry,been extremely busy with our dog kennels and getting stuff ready for winter...
        Was hoping someone would jump in,will try and find some time tonight..
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
        • ddarn
          • Jun 2014
          • 76
          ok..
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            #85
            Didn't forget about you.....super busy......Here's a gentle bump...selldoor,budm,tom66 anyone? I need some help with this one,too busy and it's getting close to being over my head
            • ddarn
              • Jun 2014
              • 76
              bump
              • ddarn
                • Jun 2014
                • 76
                Coming back to fixing this tv....power board checks out ok,fuse is ok..but yet it looks like I have no power to the tv since the standby light is off when plugged in...could it be the cord itself?
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  #88
                  This is old and long post so let's start fresh.
                  Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
                  Format:
                  Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
                  1 - XXXXXXX - XXv - XXXv
                  2 - XXXXXXX - XXXv - XXXv
                  3 - XXXXXXX - XXXv - XXXv
                  4 - etc.
                  • zape
                    • Jul 2017
                    • 176
                    Working on the same board, observing similar symptoms, "all 5v" measures 4.4v when disconnected and 4.1v when connected to the main board.
                    P-ON-H2 is 0v
                    Not sure what P-ON H1 for and why there are two of them
                    • zape
                      • Jul 2017
                      • 176
                      Well I jumped the P-ON-H2 to AL +5v and the power board turned on just fine. +24v and some other voltages are present.
                      So it's the main board which is faulty then. It does not send the turn on signal to the PSU.
                      I have the same TV as in attached service manual by Budm above: https://www.badcaps.net/forum/showpo...7&postcount=46.
                      The motherboard is ba17f1g0401 4_1
                      Checked the AL +3.3v on the main board and it is present.
                      What would I check next? The owner said there was a power surge or something.
                      • zape
                        • Jul 2017
                        • 176
                        Found out that P-ON+3.3V is shorted to ground on the main board (2 ohm)
                          What is your TV model number?
                          https://www.shopjimmy.com/emerson-a1...-main-cba.htm#
                          Is this your board?
                          I do not any pin out printed on the board for the P-ON+3.3V.
                          • zape
                            • Jul 2017
                            • 176
                            Magnavox 32MF301B/F7
                            Board looks similar with 4_1 at the end instead of 5_1
                            there is no any markings on the board
                            P-ON +3.3v is produced by IC3001 on the main board, see page 45 on the manual on the link above
                            • zape
                              • Jul 2017
                              • 176
                              checked the MLC caps and the diod and the're good
                                There are lots more caps connected in parallel to the PON-3.3V, some of them through the small inductors, not just what you have highlighted if look thorough the whole page, it is also fed to some other pages of the circuits too.
                                • zape
                                  • Jul 2017
                                  • 176
                                  Yeah it's spread over the board, unfortunately I don't have a thermal camera
                                  No idea how to find the short.
                                    P-ON 3.3V Source and filter caps.
                                    How many Ohms do you get on that line?
                                    Magnavox_32MF301b-f7_chassis_fl11-4
                                    • zape
                                      • Jul 2017
                                      • 176
                                      2.0-2.1 Ohm
                                        It is going to be fun trying to find out which cap is shorted out, there are so many MLCC connected to that line.
                                        • zape
                                          • Jul 2017
                                          • 176
                                          I'll try to remove inductors
                                          so it is not after L3026 and L3019
