Emerson hdtv troubleshooting
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Emerson hdtv troubleshooting
    OK need test no more in that area 160.8 on Big cap is a good start.
    Its late here so hopefully others will pick up now.
    • ddarn
      • Jun 2014
      • 76
      yes hopefullly..
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        No-one eh!
        ok using just that power board just carefully check again the VDC on that main cap.
        If that is still there set meter on 200vdc and at various places on the board there are wire jumpers that have a voltage marked on them. Stay out of the primary Hot Area and test a few. Some are marked gnd put your black probe on that and probe the voltage wires with the red. Remember keep clear of the white hot section. Try and do 3v 5v 24v
        • ddarn
          • Jun 2014
          • 76
          check the big cap again with power to the board again or unplug and check again?
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            power on the board...if all is well,you should see around 160 volts DC on there....
            If you DO measure that 160v DC,then do what selldoor suggested and look at those wire jumpers with voltage markings beside them...black probe on a wire jumper that says GND and red probe on the 5volt,3 volt etc...
            I'd say the "all 5volt" wire jumper would be the most of interest for now,but check the 3volt etc too...
            If you DON'T get the 160 volt DC on that main cap,we need to trace backwards,but then report back,as the voltage switches from DC back to AC at those 4 diodes...
            Proud owner of dozens of broken TV's and many,many,many boards.
            Our website and passion:http://hollenhundshepherds.com/
            • ddarn
              • Jun 2014
              • 76
              166.5 vdc..a certain area on the board to read the jumpers? they have over 50 easily and are reading different..
              • ddarn
                • Jun 2014
                • 76
                I did 8 readings and I didnt see any jumpers for 5 volts..most of the ones I saw had 24v next to them.I also attempted to use a GND jumper that was near the jumper I was reading..readings are below:
                J1061 (7.5V rating)--0 VDC
                J1123(6V)--6 mV
                J1125(3.3V)----0VDC
                J1106 (.16V)---9.2 mv
                J1081(24V)---9.31V
                J1082(24v)---9.30V
                J1059(12v)--.209V
                J1101 (36V)--14.43V
                • martino
                  Not so "senior"
                  • Aug 2013
                  • 997
                  • canada
                  #28
                  you won't see 24 volts etc untill we force on the power supply...
                  see pic,I marked the all 5 volt and GND and also ps-on...
                  Meter on DC scale,black on GND,red on all 5 volt jumper wire.... ?? volts?
                  Now,if you DO get 5 volt on the all 5volt jumper,then it's time to test if the mainboard tries to turn on the power supply...
                  Plug powerboard back in to mainboard and ALL other connectors...plug in the TV,put black probe on GND,red probe on the ps-on jumper wire,you will see 0 volts,KEEP probes on thse points and hit the power button on the tv(or remote)and see if now you read a voltage,could be anywhere from 1.8 to 5 volts...
                  • ddarn
                    • Jun 2014
                    • 76
                    I got 4.43 Volts..
                    • martino
                      Not so "senior"
                      • Aug 2013
                      • 997
                      • canada
                      #30
                      On the all 5 volts or the ps-on?
                      • ddarn
                        • Jun 2014
                        • 76
                        On the all 5 volts
                        • martino
                          Not so "senior"
                          • Aug 2013
                          • 997
                          • canada
                          #32
                          4.43 volts......seems a tad low,how fresh is the battery in your multimeter?
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #33
                            Perhaps check the voltage on the cap C639 it is 10v so likely to be on 5v line.
                            It is just by the big transformer that goes from Hot to cold
                            • ddarn
                              • Jun 2014
                              • 76
                              yes,I believe battery is good but I will use another meter and see if it comes up with the same thing.
                              • ddarn
                                • Jun 2014
                                • 76
                                the other meter(fluke 7-300) reads 4.33 V.......c639-- 1 meter reads 2.678v(fluke 7-300) the other 3.55v(craftsman 82372)
                                • martino
                                  Not so "senior"
                                  • Aug 2013
                                  • 997
                                  • canada
                                  #36
                                  I don't like that 4.33 or 4.43 volt,selldoor you think that's too low too?
                                  I assume you measured that with the main board disconnected,right?
                                  Could we get a clear close up picture from the bottom side of the power board,showing the area where the all 5volt etc is?
                                  • ddarn
                                    • Jun 2014
                                    • 76
                                    yes the main board was not connected..I will take a pic of the bottom side of the power board when i get off work tommorrow morning.
                                    • ddarn
                                      • Jun 2014
                                      • 76
                                      the shopjimmy pic in post 14 will probably be clearer than mine..the shiny back on the board blurs my pics...I will upload a couple though and see if you can make anything out of them.I think the 3rd one is the least blurriest..good luck...
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        #39
                                        May as well delete all except 3
                                        Martino yes I think its too low but no idea why.
                                        • martino
                                          Not so "senior"
                                          • Aug 2013
                                          • 997
                                          • canada
                                          #40
                                          I'm on the road so can't really see pic good. But I'm thinking of a Zener diode dragging down the 5 volt a bit. Wanted to see the traces to trace back the 5 volt line to transformer.
