Request: Schematic for LG 42PX5D-UEB.AEKYLJP with bad PSU caps & broken Y-Sus Module?
  • SlySven
    • Jun 2014
    • 7
    • Great Britain
    This is my first attempt at a Plasma TV repair on a broken set that was donated to a good home. Inspection revealed 2 of 3 3300uF 10V (IIRC) Samwa Caps (Code U9A PET) blown on the PSU and a dead (Y-Sus O/p s/c to Vs & Gnd) Y-Sus IPM on the 6871QYH953A Y-Sus panel. I checked the 4 power diodes around it and they seemed OK but after replacement of the failed items (and a fuse) I'm still left with a non-working unit.
    Having read-up on this forum about IPM failures I took the opportunity to fit a fan to the heat-sink and did the same to the Z-Sus panel - I'll wire them up when I get it all working. At this point after running the set for a few minutes and probing around the Z-Sus module is warm but not unduly so but the Y-Sus IPM seems cold and unheated by doing any work, the display is blank with no hint of any glow, I was able to see a waveform of ~200V amplitude on the "Waveform" test point on the Y-driver/buffer and I can see on the 'scope signs of what must be an OSD signal which would be "stepping" across the display if it were to be visible. As far as I can tell the supplies to the Y-Sus panel are now OK. I noted down various high voltage supplies around the set:
    Va = 60.0, Vs = 188.1
    and on this panel:
    P102 = 119.5, P101 = 200.4, -Vy = 200.1
    all of these and the floating 5 and 15 V supplies seem good and quite close (bearing in mind the apparent low "loading" on the lines) to the printed label. And Vz is 99.9 on the Z-Sus panel.
    Now I've seen that others have had fun with boards like this but this leads to my main question: Has anyone been able to track down an actual schematic diagram for this (6871QYH953A) panel? I've been able to download a free "Service manual" for the LG branded receiver but - as seems to be the standard for these LG Plasma Display based units - it only gives the circuit diagram of the control/system panels not the PSU and driver ones.
    I do have a SOT23 SMD transistor (Q16) that has been broken away from the PWB (it became "unstuck" and lost a leg) - I think I caught it whilst working on the Panel. It is the only one of it's type on that panel and it seems to be around the buffering of the control lines where they arrive at the PWB from the SysCon board, I can't tell what effect it would have and that is why I think the diagram would help me (and to identify a replacement).
  • SlySven
    • Jun 2014
    • 7
    • Great Britain
    Re: Request: Schematic for LG 42PX5D-UEB.AEKYLJP with bad PSU caps & broken Y-Sus Mod
    Just for the record - it has been an awfully long time since my last post - I'll update on what I needed to do further to fix this beasty:
    I had to replace the YSUS module! It cost me over £40 but I managed to source on and it was worth it - though it was a nightmare getting the blasted thing off the PWB. I remember it was a dark gray ceramic/metallic hollow block about several inches square and perhaps 5 to 8mm thick with around 15 pins (it was a long time ago and I don't remember exactly) down two opposite sides AND it was bolted to a massive heat-sink. I had a hell of a job getting all the pins unsoldered and at one point I had it resting on a pair of right angled pieces of aluminum - one strip per set of pins - on top of my ceramic hob trying to get enough heat into all of them at the same time to melt the solder.
    Unfortunately that didn't work!
    Finally got my most butch soldering iron out and with a combination of some braid and a sucker (the device, not me ) managed to get the thingy off the board. Being curious I saw that the underside of the module was sealed with a grey rubbery filler which I manage to pick away to reveal several square inches of simple SMD component and some active FET/transistors devices (actual pieces of silicon with bonding wires to adjacent PWB) bonded directly to the internal PWB and encapsulated inside transparent poly-resin. Closer examination showed that the two that were dead shorts looked visibly damaged under the clear coating where the bonding wires touched the semiconductor!
    Anyhow after attaching the replacement module to the monster heat-sink, re-soldering it to the panel and then wiring up the additional cooling fans the TV has been doing sterling service for the last couple of years even without getting a diagram to work from.
    Only mild niggle is that the sleeve bearings in the cheapo fans I added to the heat-sinks are drying out and they don't always turn silently any longer so at some stage I am going to have to man up and get the massive 40Kg unit off the set of raw-bolts and spacer straight into a structural wall of my house - without rupturing myself - to refit some better ones...
    • pni
      Backlight panel diffuser melt by backlight leds broken
      by pni
      Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
      10-12-2025, 12:08 AM
    • edugimeno
      Nevir 39" LCD acting up. Broken panel?
      by edugimeno
      Hi! I got this TV that was supposed to "not work well".
      I turned it on and the BL got lit but nothing was showing on screen
      Opened it and found that the only PS voltages present (12v and backlight) were 100% perfect
      Plugged it back in and the screen kind of started up showing a NEVIR logo but it was split into several chunks with also missing lines in between. Nothing else
      Next time the screen showed an amorphous large color cloud in the screen swinging from side to side (maybe a screensaver picture) with all broken lines everywhere....
      12-15-2022, 10:55 AM
    • PlasMatt
      LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
      by PlasMatt
      I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
      09-20-2025, 06:50 PM
    • howardc64
      LG 49UJ6500 LCD panel lighter band that goes away
      by howardc64
      49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
      Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
      02-19-2023, 12:13 AM
    • triplefour
      SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
      by triplefour
      TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
      tcon is built into mainboard.
      Only one cable goes to panel boards.
      there is a cable from one panel board to the other that links them.
      cost cutting measure that results in us having harder time to diagnose.
      removing the link to the second panel board allows TV to stay on with stable backlight but no image.
      used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
      07-28-2022, 07:59 PM
