Sony KDL46Z4100 Pic Off / Timer blinking slowly
  • LacoKis
    • Jun 2014
    • U.S.A.
    My TV started freezing intermittently with colored patterns on the screen (not just simple horizontal/vertical lines) and the red Standby LED on and the orange Pic Off/Timer LED blinking slowly (about 5sec on / 1sec off). I can't google that combination anywhere except for one single thread. All I can find is about the red Standby LED flashing quickly. Does anyone know what the slow orange LED blinking means?
    The freezing got progressively worse over a few days, but usually when I would unplug the TV and let it sit for a while, I would get it back to working, at least for a few minutes. Other than the freezing and blinking, there were no issues with the picture or sound quality.
    Anyway, I bought a new BU board off eBay. Replaced the old one and now whenever I turn the TV on, the green LED turns on, the backlight turns on, and then after about 10-15sec the same solid red LED and slowly blinking orange LED. However, about a minute later, the power relay clicks and turns the TV off. And then I get the more standard red Standby LED by itself, blinking 12 times.
    Per the service manual, 12 blinks is a T-Con error. So should I now try replacing the T-Con board? But with my original BU board I never got to the 12 blinks, just the slow orange blinking going on and on. Who/what should I trust now? Is the new BU board bad as well or is it the T-Con? I would hate throwing out $100 for a replacement T-Con just to find out it is something else... Does anyone knowledgeable have any suggestions?
    As I mentioned earlier, I found one thread, http://www.avsforum.com/forum/166-lc...y-support.html with the exact orange blinking symptom. In that thread, the OP replaces the BU board just to get the 12 red blinks. In the end, it seems that he/she replaces the BU board once again and gets a working TV, but it is not 100% clear if it is indeed a 3rd BU board that saves the day or a T-Con. Anyway, the first half of the story is very similar to mine.
    I would appreciate any help at all reviving my TV,
    Thanks,
    LacoKis
  • Jacksoft
    HP ProBook 440 G6 infinite orange blinking
    by Jacksoft
    I have an HP ProBook 440 G6 with DAX8JMB16E0 REV. E motherboard that got BIOS bricked after maaany bootloops caused by Window's BCD. I made a dump of the actual BIOS and written a found one.
    The PC worked but it was very slooow to show HP logo in first place.
    A friend of mine gave me another BIOS for this series and after the flash it powered on (white led on power button) but after few second shutted down and start blinking orange infinitely on the LED near the AC adapter connector on the side.
    The laptop doesn't power on anymore, and the blinking led happens...
    08-29-2025, 01:24 AM
  • noipi
    DELL INSIPRON 14 No power blinking orange/white
    by noipi
    i have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
    05-06-2025, 08:08 PM
  • jorpec
    HP Elitebook 8460p battery led white and blinking orange
    by jorpec
    Hello everyone
    I have this Elitebook that wont turn on, only the battery led is white and blinking orange, does this even without battery.
    If this is a error code i couldn't find any info about it.
    Already tested with a another charger, measure the presence on 19v on the 19v rail, checked if there was capacitors in short-circuit
    Thanks...
    05-05-2025, 04:39 AM
  • DeanWy
    WD Sentinel DS5100 (NAS) boot issues
    by DeanWy
    I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
    It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
    There...
    07-30-2024, 04:13 AM
  • YasaCh
    Sony kdl 40p5500 red light keeps blinking 3 times
    by YasaCh
    Hello...
    my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
    i opened the back cover no sign of damage on the powery suply or motherboard
    when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
    another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
    07-07-2025, 11:53 AM
