Dell W4201C HD
  • whiz62
    whiz62
    • Dec 2013
    • 242
    • usa
    Dell W4201C HD
    This forum has struck again. I just got this monster home today with the help of my brother. We are no spring chickens. After fixing our sharp 32" crt TV for horizontal lines, my buddy's Samsung flat screen, my Delll monitor for my computer out in the garage, a Samsung flat panel for my grandkids, a RCA flat with DVD, and Philips 40" Lcd/Led I could not resist this.
    You guys make me do things I would never dream of doing. It was cheaper than a round of golf and will be just as satisfiying as well as aggravating.
    Just got the power board out and pulled the two known bad caps out and they were bloated and and had high ESR. Here we go! Don't think I will go this way again. It is all your fault even though I can't help myself.
    My garage is getting full. My wife is gonna kill me! My neighbor said I should open up a sports bar in here! I still says it's all your fault.
  • whiz62
    whiz62
    • Dec 2013
    • 242
    • usa
    Re: Dell W4201C HD
    stopped by and got caps today and got the tv fired up and working great. we will see for how long .
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
    • diamon
      Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
      by diamon
      I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
      Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
      Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
      Pictures of these boards:
      Dell Latitude 5520 https://www.ebay.com/itm/256052956663
      Dell Latitude 5530 https://www.ebay.com/itm/125844181534
      Dell...
      02-28-2024, 12:51 PM
