Sansung 42in Plasma
  • Hornnumb2
    • Feb 2011
    • 218
    Sansung 42in Plasma
    Have a samsung 42 in plasma that started having green and red shadows around objects. The power board was replaced a couple of years ago. Sorry I can't get the model number off the back, it's mounted flush inside a cabinet. I posted some pics on photobucket, hard to get a good picture of it. Thanks Michael
    http://s1371.photobucket.com/user/Ho...y/?view=recent
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Sansung 42in Plasma
    Based on absolutely nothing but these pictures, my guess is the X-Main. But pictures of the boards with the back off and a model number would certainly be a good start.
    • Hornnumb2
      • Feb 2011
      • 218
      OK let me see if I can get this thing out. It is screwed to a shelf inside a cabinet it barely fits in with equipment under it. The shelf unit and tv fit into the cabinet as one piece, not the lightest or easiest to get out. Thanks
      • Hornnumb2
        • Feb 2011
        • 218
        Model number is SP-P4251 and I added some more pictures to the album. Thanks Michael
        • ArMaaN376
          Samsung PS51E550 Plasma TV
          by ArMaaN376
          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
          Opened TV cover & observed foll
          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
          How to confirm Y -Buffer board...
          06-19-2024, 04:05 AM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
        • KYBOSH
          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
          by KYBOSH
          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
          No picture but you hear the TV static (white noise) playing loud and clear.
          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
          But it seems they didn't get too far and just left it.
          When I first took a look I was amazed at how pristine the inside looked.
          Its as if the TV had been in a time capsule.
          Caps looked like they were just pulled off the self.
          Copper coils had no sign of corrosion on...
          02-01-2023, 11:10 PM
        • alltvrepairs
          Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
          by alltvrepairs
          I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
          I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
          Any one met this problem in the past?...
          10-08-2025, 07:34 AM
        • chazh
          LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
          by chazh
          This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
          I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
          The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
          09-01-2025, 08:56 PM
