LG 60uh614a horizontal lines
  • vbrad511
    • Feb 2015
    • 70
    I've got a 60uh615a that has random horizontal lines, but they jump around and shuffle. Sometimes there are "square-ish" "boxes" that appear and disappear. Does this sound like a bad panel, or is a t-con board a possible culprit?
    Thanks,​
  • nomoresonys
    • 12332
    • U.S.
    Maybe inspect the flat tcon cables for damage and clean the contacts with a pencil eraser or isopropyl alcohol both ends and retry.
    • EazyBone
      • Jun 2023
      • 1362
      • United states
      Video? I feel like lines are 95 percent or higher to be panel issues.
      • vbrad511
        • Feb 2015
        • 70
        That's what I've thought too, but the fact they're not constant...that they move, has me wondering. I'm going to clean and reseat all the connections and see if anything changes. Thanks
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • Ihandyrepair
          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
          by Ihandyrepair
          Hi guys
          I just started fixing 4k TV few months ago. so I am still learning a lot
          I got this tv from friend complaint is ghosting or horizontal lines on image.
          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
          then it started to show the ghosting white image.
          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
          it has 3 thin small boards at the bottom of the...
          12-05-2022, 04:18 PM
        • ggil44
          Sony XBR-65X750D Horizontal lines bottom of screen
          by ggil44
          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
          05-30-2023, 07:51 PM
        • rstrube
          ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
          by rstrube
          Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
          Hi Everyone,
          I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
          Yesterday, 01:37 PM
        • rstrube
          by rstrube
          Hi Everyone,
          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
          Yesterday, 12:19 PM
