Hikvision DS-7216HGHI-K1 80350_P rev 1.1 Dump bios
  • fearti25@gmail.com
    • Aug 2018
    • Argentina
    Could you help me... I have a Hikvision DS-7216HGHI-K1 password
    Could you help me to repair the dump please. Thank you.
    The model: DS-7216HGHI-K1
    Main Board 80350_P rev 1.1
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • mkdj
    by mkdj
    Dear all,
    10-19-2025, 04:41 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • haitham sharabati
    by haitham sharabati
    Hello engineers 😀,
    🔧 Device Info:
    - Model: HP 15-da2007ne
    - Product Number: 8XF55EA#ABV
    - Serial Number: CND0338P0D
    - CPU: Intel Celeron N4000
    💀 Problem:😅
    08-07-2025, 04:54 AM
  • robgerr
    Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
    by robgerr
    Good morning forum, I'm trying different bios to try to resurrect this machine, with all the bios tried the machine turns on, the fans turn but the screen is black. I tried to download the correct bios from the Asus website (x3500PC by reading the QRCODE from the motherboard) but this is a PFAT AMI, I managed to decrypt it but I get several files and rebuilding it is very laborious, I tried with the uefi tool to extract only the main bios and cut the decrypted one and rebuild it in hex but it doesn't work the same. Wondering if anyone has a dump for this main board. I thank you.
    Attach...
    11-17-2023, 09:52 AM
