PN42B450 No Video
  • war6763
    • Jan 2010
    • 12
    PN42B450 No Video
    Good evening everyone!
    I'm working on a Samsumg PN42B450 42" TV and I'm stumped. I can't figure out what's going on with this TV; here's what I've done:
    • Tested the Y-Buffer PCB. No shorts or burned components.
    • Tested the main power board. All voltages correct, trimmed, and present. Powering off the TV kills the PSU, turning it on causes all voltages to stay steady.
    • Tested the Y-main board. No issues with voltage, no shorts on the ICs connected to the heatsink, caps all look good. No shorts.
    • Tested the X-Main board. No issues with shorts on ICs or Caps, no shorts, etc.
    • Tested the main board, LED blinks properly, all connectors in good, properly seated condition. Running the test pattern yields no image.
    • Tested all fuses, they're all good!!
    All the capacitors look good, no components are burned or show signs of dying, etc.
    One thing to note, the screen will sometimes start showing an image for a split second. Sometimes because I was moving a capacitor or tapping on something on the Y-Main board. This may have also been a fluke.
    If you look at the screen while activating the menu on the remote, you can see a change in the "black" screen. It becomes slightly lighter. I'm also not sure if invoking the screen test by shorting pins 3 and 4 on that connector on the Main Board should also produce sound. If it should, then I can't hear anything!
    Please let me know what you guys think!!
  • war6763
    • Jan 2010
    • 12
    Re: PN42B450 No Video
    Can I get a mod to fix the title? I goofed and didn't add the make.
    • capkid
      • Oct 2010
      • 1339
      You mentioned that the LED is blinking normally. Did you mean the logic board's LED? Did you check for bad solder joints?
      Regarding test patterns, is the test you performed? https://www.badcaps.net/forum/showpo...61&postcount=2
      LG Plasma Mal-Discharge Correction Service
      • war6763
        • Jan 2010
        • 12
        That's right, the logic board's green LED is blinking at about 1Hz. I checked the Y and Z boards for cold solder joints.
          Any subtle glow from the plasma panel in a dark room?
          • war6763
            • Jan 2010
            • 12
            There is! The glow will also change when I press the "menu" button on the remote!
            • capkid
              • Oct 2010
              • 1339
              How is your VE voltage on the X-main?
                It could be a control board issue...
                • capkid
                  • Oct 2010
                  • 1339
                  Yeah, it appears to be either the X-main or the control board. The fact that you have no test pattern onscreen, if the test was performed correctly, and the LED is blinking normally seems to point to a bad control board. I'd still check the VE on the X-main.
                  • war6763
                    • Jan 2010
                    • 12
                    On this particular model VE comes from Y-Main directly, and measuring that on the board is 90V (as expected), at least at the connector.
                    I've been suspecting the control board as well.. Let me get one on order and I'll get back to you guys!
                      Even if X-main were bad completely you'd still get a partial picture unless control board gets confused by a bad board and stops driving panel properly.
                      • war6763
                        • Jan 2010
                        • 12
                        No dice. I just installed the replacement control board and the TV is doing the same thing.. Anything else you guys might recommend?
                        • war6763
                          • Jan 2010
                          • 12
                          Can anyone help me find some test points to look at with the scope? I would love to figure out what's wrong with this TV..
                          • jjanssen7
                            • Nov 2012
                            • 252
                            I have the exact same TV with the exact same symptoms. If there is anything you want me to look at mine to help you with a solution let me know!
                            • war6763
                              • Jan 2010
                              • 12
                              I should also point out that the "screen glow" is no longer present after replacing the board. Also, the Z-sustain board is VERY loud. Maybe that has something to do with why I still can't get an image on this TV?
                              • jjanssen7
                                • Nov 2012
                                • 252
                                Maybe Tom has some advice, all I know is that mine has the exact same symptoms (have done the same tests as you)... I have not replaced my control board, but If you Google the board number and dig a little there are others out there that feel this control board might be suspect after testing as normal y & X boards. How sure are you that the control board is good?
                                  What scope do you have?
                                  Do you have a 10X 400V probe available?
                                  • war6763
                                    • Jan 2010
                                    • 12
                                    I've got a 500MHz scope with a couple of 100, 400, and 1kv probes.
                                    • jjanssen7
                                      • Nov 2012
                                      • 252
                                      WAR6763, where you able to get anywhere with this symptom?
                                      • tvtimmy
                                        • Mar 2015
                                        • 1160
                                        • usa
                                        I had one that had screen glow. It turned out to be a blown fuse on the E or the F board.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                        • DynaxSC
                                          Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
                                          by DynaxSC
                                          I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
                                          I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
                                          Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
                                          Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
                                          05-04-2025, 12:08 PM
