Samsung PN50A550 No Power
  • crdz66
    • Nov 2012
    • 242
    Hello Everyone.
    I have a Samsung Plasma Tv with power problems.
    This Tv come to me with a power problem like turn on - turn off.
    Everything on the Power board looks ok. (caps, no burning signs, etc)
    So, I did a sample test shorted pin1 - pin 3 from main board ribbon cable and short pin3 and pin4 over logic board.
    So, the tv keeps on for 5 minutes. After this time, I took this tv of to my bed and I try stand over the floor reclined on the wall.
    As soon I turn on, I saw a short(bright light) comes from y-board or Buffer Boards.
    So now the tv refuse turn on making clicking noises.
    Stand by keeps 5volts.
    No generate vs or va voltages.
    The fuse fs803 was blow out and I try to use another with higher amperes, but still blow everyone that I used.
    Any Ideas.
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • mrtek
    Samsung UN43NU6950FXZA No power
    by mrtek
    Hi
    Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
    Main fuse = OK
    Back light LED = OK. Power them with aux power source
    LED output = OK 156V
    I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
    Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
    07-20-2025, 08:06 PM
  • Journey11
    Samsung TV won't turn on ... keeps cycling the power relay on & off
    by Journey11
    Hi All,
    First time posting here ... my name is Kevin but my friends call me Journey.
    I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
    After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
    It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
    07-04-2024, 02:44 PM
  • Cooperr
    Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
    by Cooperr
    I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
    The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
    10-21-2025, 01:11 PM
