Sanyo dp42840 - Power board cycles and relay clicks
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Here is a Sanyo dp42840 that someone already recapped but could not get working. Upon opening it up, I immediately saw a domed Nichicon 1000 uF 16V cap on the power supply. After changing it and checking all other caps on the power supply, I powered it up. All output voltages read OK until it got warmed up and then started cycling and clicking. Sometimes it would get far enough to flash the backlights just for a quick quarter of a second.
    Trying to isolate the problem, I disconnected all other boards and simply did the ps_on jumper to 5V. The board then continues to cycle with nothing hooked up to it. I am now questioning the large caps in the primary main power circuit. There are two 470uF's and they are both reading 420uF. Is this low enough to cause the problems that I am seeing???
  • SlickClick
    • May 2011
    • 91
    Re: Sanyo dp42840 - Power board cycles and relay clicks
    Maybe; most electronics allow for up to 5% variable; anything over or under that is ruled out of spec in my book; but could be good/in spec as per build quality... I have seen swollen caps on PSUs and the board still gave fine voltages...
    on a side note: id suspect a transistor or transformer failing/failed on the PSU somewhere; pics help...
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      Pics of the boards may be coming soon. After re-evaluating the situation. I don't think testing the power board with the PS_on jumper helps on this set. I plugged in all the other boards and, as before, the voltages come on solid for the output. All are present and none are low.
      • mu2
        • Oct 2009
        • 217
        I have seen two of these sets - same model as yours with bad backlights.
        The last one I repaired had the two seconds to black problem and I took the panel apart. There were several bad bulbs in various stages of decline.
        Perhaps you have the same issue and when the lamps warm a bit they trigger the protection circuit.
        I have an inexpensive source for the lamps (18 of them).
        If you send me an e-mail off list we can talk.
        I'm not that far from Pittsburgh.
        Mike
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          This may help also
          http://www.youtube.com/watch?feature...&v=KSYCn93pz6k
          • SlickClick
            • May 2011
            • 91
            I have never really seen back lights themselves go bad maybe once in a laptop from the mid-90s but otherwise the bulbs for the back lighting rarely go bad unless physically broken... But one never knows maybe a large batch of bad bulbs made it into production...
            In all honesty if its a backlighting issue and you can actually still see the image when the unit is on; id take the time to try and retro fit some LED low voltage light strips in place of the bulbs add a small dial to regulate brightness done..! LoL I just said that cause i want to try it but dont have a donor with a backlighting issue yet...
            Again i have a 42 inch sanyo with everything but the LCD screen and T-con took that off to fix another sanyo 42incher and called it my frankenvision; took the display off the backlight housing and out in another sanyo 42 with a different backlighting case/setup... TV works great now too btw... with that said make sure that when you order the bulb you get the right ones cause of the 2 i have it would seem the backlight panel setup is totally different entirely...
            on a side note watch: http://www.youtube.com/watch?v=KSYCn93pz6k
            • Dgtech
              E. Technician
              • Apr 2009
              • 1462
              • Steeler
              I watched that video before I got started. I checked all the test points and all is well. I have all voltages and the unit just keeps clicking off then on. Wait about 15 seconds. Click off and on. And so on...
              The bulbs would make sense at this point. Im not going to take it apart that far just to find the bad news. I'll sell it before I do that.
              • SlickClick
                • May 2011
                • 91
                I want to say that if you disconnect the inverter board from the PSU the unit may fire up; since you said the PSU seems to be providing the required voltages...
                If I remember right you can disconnect each bulb from the outside of the case to the Inverter board; disconnect all of those first and try to fire it up... if it comes on and you get and image and sound than you know its a bulb backlight issue if it keeps shutting down try disconnecting the inverter board as previously mentioned... if it still turns off most likely the PSU is bad or the mainboard is bad and is failing the boot check and shutting down... LCD are rather simple to figure out compared to plasmas...
                • tom thumb
                  • Jul 2013
                  • 66
                  I agree that is could be the light bulbs
                  But I have also run into similar problems on several Tv.s going into protection mode
                  and I eventually found out It was just a bad solder joint on power supply
                  I reheated the solder joints on the mosfets and the transformers
                  and everything works fine again.
                  I would try reheating as many solder joints as possible before tearing it farther apart.
                  It might help and hopefully it won't hurt
                  Just and Idea for ya to try
                  • Rensiee
                    Panasonic TH-50PX8EA Black screen, only relay clicks
                    by Rensiee
                    I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                    I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                    When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                    I have measured the voltage in the VSUS line, which...
                    06-18-2024, 12:58 PM
                  • TrisHCl
                    LED TV Boot loop - UE40F6500SB
                    by TrisHCl
                    First post...
                    I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
                    Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
                    I disconnected the main board from the power...
                    02-06-2025, 08:42 AM
                  • samtron786
                    toshiba 46xv555d relay clicks
                    by samtron786
                    Hello
                    The red and green LEDs both light up and you can hear the relay click. (no picture, no backlight, no sound)
                    2-3 seconds later the relay will click again and only the red LED will stay on.
                    I would be very grateful for any advice or a little help.
                    circuit diagram?
                    Thanks very much
                    02-04-2023, 04:39 PM
                  • jm1234
                    9V relay temperature 40C
                    by jm1234
                    Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                    I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                    05-09-2024, 03:03 AM
                  • edugimeno
                    Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                    by edugimeno
                    Hi everyone!
                    I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                    I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                    This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                    To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                    I respected the polarity, positive to cathode of protecting diode
                    So provided all...
                    04-18-2024, 01:15 PM
