Lg 60pk590 half screen fault
  • wreksta
    • Aug 2013
    • 508
    • england
    Hi all can you help I have this set I bought it cheap as gets half a screen only
    I replaced the top buffer board as It never heated the heat sinks at all on upper buffer
    Bottom buffer heats up no problem
    I've tested the y main all mosfets diodes check out
    Could a test mode bring full screen on
    I have checked the y board over and noticed 3 resistors that are located near where top buffer is someone has worked on them before as soldering is lumpy
    Any ideas please
    Y main part number EBR63450401
    Upper buffer EBR71853501
    Edit
    Auto ex gen test mode works on lower screen only
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • howardc64
    TCL 49S405 double image
    by howardc64
    LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
    This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
    06-23-2025, 03:20 PM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • valvashon
    LG 55UH6150- trouble powering up, then half lit screen (pictures!)
    by valvashon
    The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
    Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
    11-24-2024, 12:08 PM
