bad tcon?
  • bmmc
    • Nov 2009
    • 13
    bad tcon?
    lg m#42lg50 solarized pix but osd is clear.does the good osd rule out the tcon?
    Re: bad tcon?
    In most cases yes, but there are a few exceptions. If the TV has 100Hz/200Hz motion processing the OSD is usually not processed by this and so is sometimes not affected by a bad T-con. Picture of the fault?
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
    • advant
      by advant
      02-03-2020, 12:25 AM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
    • Daren87
      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
      by Daren87
      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
      08-13-2023, 03:25 PM
