Pioneer Kuro PDP-LX5090 7 blinks intermittent
    Re: Pioneer Kuro PDP-LX5090 7 blinks intermittent
    I was able to rid the red tint and get the black level so low that I cannot see it except with the no signal display. When watching a movie it is completely gone. I want to tweak it more to see if I can sort out some black level unevenness on the no signal display (disappears with video display.)
    VOL SUS = 155 (from 128)
    VOL OFFSET = 140 (unchanged)
    VOL RST P = 009 (from 031)
    VOL XPOFS1 = 085 (unchanged)
    VOL XPOFS2 = 045 (unchanged)
    VOL YKNOFS1,2 D = 015 (from 143)
    VOL YKNOFS3 D = 110 (from 128)
    VOL YKNOFS4 D = 170 (from 128)
    Conventional Kuro wisdom says to adjust all the KNOFS voltages by the same amount - but you get significantly better results by not doing this.
    These voltages will vary for other panels but work for mine with 12,500 hours usage and 600 billion pulse counter.
    • Shinju
      • Mar 2014
      • 1239
      Well done sir. So what program are you using to get into the TV via USB/RS232 connection?
      My PDP-V402 has that RS232 port and most of the deep calibration options are done via that port.
        I'm using CuteCom on Linux. You can also use HyperTerminal on Windows.
        9600 baud 8N1
        Send: \x02**PON\x03 (\x02 is hex for 0x02, etc.)
        and set should power ON
        Then send \x02**FAY\x03
        to enter service menu.
        Everything else is done with remote control. PANEL FACTORY -> PANEL-1 ADJ
        Initially you want to lower the YKNOFS1,2 D until the red tint goes. As you do this you will start to get magenta stuck pixels. Then you want to increase YKNOFS3 & 4 D until the magneta sparkles go. If you start getting IR play with VOL SUS but do not exceed 190 or the set may shut down on bright images. Lower VOL RST P until you start seeing bleed in of black pixels when switching from 21:9 to 16:9 content.
        • Bjames
          • Mar 2017
          • 3
          • Us
          #64
          I have a pioneer pro 1150hd with the same 8 blinking lights that would turn on sometimes but finally just gave the quits. Im not sure how similar these twoodels are but i have to imagone there similar enough to diagnose. I have already tested to power supply board and there is still power going to the main board and audio board. Thanks and if imin weong forum jus let me know
          • heavymachines
            • Mar 2011
            • 1028
            Originally posted by tom66
            Bingo
            NJM2846 on board 1.8V regulator
            Working = 1.79V
            Faulty = 0.01V, control signal & Vin still present (3.3V)
            On Audio_IO board
            Did you check this? Tom66 has given a huge clue... Did you read entire thread?
            • pixelcap
              Pioneer Kuro Pro 111FD 8 red blink error
              by pixelcap
              Pioneer Kuro Pro 111FD 8 blink red LED.
              I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
              So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
              based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
              10-06-2024, 11:26 PM
            • GoodCapDude
              Sony XBR-75X940E intermittent 6 blinks error code
              by GoodCapDude
              Hi everyone. First post on Badcaps!
              I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
              09-20-2025, 06:07 AM
            • Biruslapio
              Panasonic P58V11B 8 and 12 blinks error "fix"
              by Biruslapio
              Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
              Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
              04-13-2021, 07:13 AM
            • Nairolf
              Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
              by Nairolf
              I have a Samsung DM32D display.
              When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
              Here’s what I have tried so far:
              1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
              2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
              3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
              From these tests, I suspect the problem might be on the mainboard. Could anyone...
              08-24-2025, 03:47 AM
            • protocold
              MacBook Pro 15" 2010 820-2850 intermittent charging
              by protocold
              I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
              I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
              when it is not intermittent:
              PPVBAT_G3H_CHGR_R is 12.07v
              when it is intermittent:
              When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
              when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
              data line on the battery...
              07-25-2025, 08:18 PM
