LG 32LB9D No sound
  • dcapper
    • Dec 2013
    • 496
    LG 32LB9D No sound
    Anyone have a way to factory reset this tv? I have had sound at times. Or any links to firmware? I did the menu on the remote and menu on the tv and there is no reset option in there.
    EDIT: WOW! I just pulled the mainboard out to take a look. It's completely warped. It must has gotten really hot before. I'm assuming this will need a new mainboard.
    Re: LG 32LB9D No sound
    The most common issue on these sets is low 3.4V from the PSU causing a variety of issues, such as nonfunctional sound, poor digital TV reception, TV not responding to the side buttons, etc.
    • dcapper
      • Dec 2013
      • 496
      Hi Tom,
      When I got it, it had one blown cap in it. I only replaced the one. Maybe I better look at replacing them all. The sound works once in a while.
      Thanks for the info
      • dcapper
        • Dec 2013
        • 496
        Oh I forgot to mention. There is 32000 hours on the tv.
          Check the 3.4V pin on the power supply.
          • dcapper
            • Dec 2013
            • 496
            I replaced all the caps and still no sound. So I tapped the power supply in different spots until the sound came on. Cold solder joint on one of the FET's. Tv is working again.
            • alfatv
              • Sep 2020
              • 353
              I had this TV for a while.
              First, looks like too much current was going through 3.4V wire, the wire and connector pins got burnt.
              Replaced the wire, soldered directly PCB to PCB.
              The TV was working, but with lots of background static digital noise.
              Replaced 2200uF and 3300uF caps in power supply, not so much noise as before, but still there is still some.
                • 12322
                • U.S.
                Might have some more bad capacitors on the board.
                  LCD LED TV Service Menu Codes
                  ALL LCD LED TV SERVICE MENU CODES
                  Service Menu Code with Board Name
                  China Universal Board / Jumper Board Service Menu Code
                  Changhong Ruba Service Menu Code
                  Ecostar LED TV Service Menu Code
                  Orient LED TV Service Menu Code
                  Haier LED TV Service Menu Code
                  TCL LED TV Service Menu Code
                  Samsung LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  Videocon LED TV Service Menu Code
                  Supra LED TV Service Menu Code
                  Toshiba LED TV Service Menu Code
                  Symphony LED TV Service Menu Code
                  Veste/ LED TV Service Menu Code...
                  10-31-2024, 03:58 AM
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                • LEECH666
                  Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                  by LEECH666
                  Good day ladies and gentleman!
                  I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                  This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                  I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                  01-19-2024, 05:46 PM
                • porfyriadhs
                  Vestel 17mb230 mainboard.No Sound
                  by porfyriadhs
                  Hello to everyone . I have a vestel mainboard 17mb230 with no sound on the speakers only on the headphones . I think that hotel mode is on but I cant find a way to fix .. Any help will be good thanks
                  03-19-2024, 01:12 AM
