Samsung UN40H5003 boot loop every ~8 seconds
+ More Options
Posts
  • eigma
    • Jan 2021
    • 13
    Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
    Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
    SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
    Main board: BN94-07592P / BN97-08922R / BN41-02263 - see attached photo.
    Multiple power supplies:
    • IC203 SMPS AOZ3015PI input 12.8V output 4.94V
    • IC204 LDO input 5.0V output 1.8V
    • IC205 LDO input 5.0V output 3.3V
    • IC201 LDO input 5.0V output 3.3V
    • IC501 LDO input 5.0V output 3.3V
    • IC206 SMPS input 12.8V output 1.17V
    CPU label: Samsung SEMS32 DNIe 1436BA7MLH88ZA, some obscure 32-bit RISC variant "AEON".
    RAM: I don't see any on the board. Service manuals refers to "Check B1.8V of DDR IC" but I don't see any DDR IC. Back of board is empty.
    SPI flash IC601_4MB: Winbond 4 MB, can be read with a SOIC8 clip, strings like "BD_SECXL1_D01B_S", "MSIF0000S3", "MBOT020600622871000", "T-MXL1AUSC-1005.0", "Hello Eden standby mode", "Enter EDEN PM Standby". Boot loader source code: https://github.com/neuschaefer/mstar-mboot
    CN801_DB debug UART 3.3V shows this output on every boot cycle:
    Code:
     Eden: BD_SECXL1_D01B_S
     SPI BOOT
     Console Initial OK
    65
    [123456789][123456789]
    0055
    BIST_0 PASS.
     MIU Initial OK 0328
    According to another post (https://www.badcaps.net/forum/troubl...08#post1274408), it should print more messages (SBOOT:AC ON, Hello Eden standby mode, ...).
    Service manual "4-2. How to Check Fault Symptom" says "Check the Q206 base, voltage must be no larger than 0.5V​". Mine is 0.57V. Is this a significant difference?
    Q206 collector does have pulses at the same time as the standby LED, so it seems involved in the power-up circuit. But I don't have schematic so I can't really understand the meaning. And my meter is a little too slow to capture them reliably. I think most rails are steady (no pulses).
    I have done some dumb basic checks like:
    - Check all capacitors for shorts, all look good.
    - Check all SMD fuses / chokes, all show continuity.
    Found some schematics here with similar main board part number (https://www.eserviceinfo.com/downloa...ain%20sch.html) but it's not exactly the same power rails, the schematics has DDR while mine doesn't, etc.
    Any idea what I could try next?
  • lotas
    • Jan 2016
    • 4741
    • Russia
    Post dump spi flash here.
    Check the resistance of the HDMI and USB signal lines relative to gnd.
    • eigma
      • Jan 2021
      • 13
      SPI flash dump attached.
      HDMI to ground - all values in ohms:
      CN401_H1 CN404_H2
      1 TMDS data2+ 30M 33M
      2 TMDS data2 shield 0 0
      3 TMDS data2− 30M 33M
      4 TMDS data1+ 30M 33M
      5 TMDS data1 shield 0 0
      6 TMDS data1− 30M 33M
      7 TMDS data0+ 32M 33M
      8 TMDS data0 shield 0 0
      9 TMDS data0− 32M 35M
      10 TMDS clock+ 31M 35M
      11 TMDS clock shield 0 0
      12 TMDS clock− 32M 34M
      13 Consumer Electronics Control (CEC) 3M 3M
      14 Utility/HEAC+ open open
      15 SCL 340 340
      16 SDA 330 330
      17 Ground 0 0
      18 +5 V 12k 12k
      19 Hot plug detect 13k 13k
      USB to ground:
      • Ground: 0
      • D+: open
      • D-: open
      • +5V: open
      Found another schematic, which seems a bit more similar to my device:
      Some things are more similar (Q207, 1.1V rail), other things are still different (input power, main IC, DDR).
      • lotas
        • Jan 2016
        • 4741
        • Russia
        Your CPU is MStar, dump is not working (broken core).
        • eigma
          • Jan 2021
          • 13
          I'm sorry, can you explain more? MStar is broken or SPI chip is broken?
          I tried to erase SPI chip and write a firmware from Samsung website, for a very similar model (though not exactly the same). The firmwares have the same first 4 KB, many other similarities, maybe a chance to work.
          But I cannot erase the flash chip:
          Code:
          $ flashrom -p ft2232_spi:type=2232H,port=B,divisor=100 -w T-MXL1JAUSC-4mb.bin
          flashrom v1.3.0 on Darwin 23.6.0 (arm64)
          flashrom is free software, get the source code at https://flashrom.org
          Calibrating delay loop... OK.
          Found Winbond flash chip "W25Q32.V" (4096 kB, SPI) on ft2232_spi.
          This flash part has status UNTESTED for operations: WP
          The test status of this chip may have been updated in the latest development
          version of flashrom. If you are running the latest development version,
          please email a report to flashrom@flashrom.org if any of the above operations
          work correctly for you with this flash chip. Please include the flashrom log
          file for all operations you tested (see the man page for details), and mention
          which mainboard or programmer you tested in the subject line.
          Thanks for your help!
          Reading old flash chip contents... done.
          Erasing and writing flash chip... FAILED at 0x00010000! Expected=0xff, Found=0x00, failed byte count from 0x00010000-0x00010fff: 0xfff
          ERASE FAILED!
          Reading current flash chip contents... done. Looking for another erase function.
          FAILED at 0x00010000! Expected=0xff, Found=0x00, failed byte count from 0x00010000-0x00017fff: 0x7eeb
          ERASE FAILED!
          FAILED at 0x00010000! Expected=0xff, Found=0x00, failed byte count from 0x00010000-0x0001ffff: 0xfe9c
          ERASE FAILED!
          FAILED at 0x00000000! Expected=0xff, Found=0x00, failed byte count from 0x00000000-0x003fffff: 0x3b5256
          ERASE FAILED!
          ERASE FAILED!
          No usable erase functions left.
          FAILED!
          Uh oh. Erase/write failed. Checking if anything has changed.
          Good, writing to the flash chip apparently didn't do anything.
          Please check the connections (especially those to write protection pins) between
          the programmer and the flash chip. If you think the error is caused by flashrom
          please report this to the mailing list at flashrom@flashrom.org or on IRC (see
          https://www.flashrom.org/Contact for details), thanks!​
          I checked voltages, /WP pin was in the middle, around 1.8V, I thought maybe that was the problem. So added a 470 ohm resistor to VCC, now /WP at 3.1V, and tried again. But still, flashrom error "ERASE FAILED!".
          • lotas
            • Jan 2016
            • 4741
            • Russia
            The firmware is damaged, it is better to erase the chip on a programmer by desoldering it from the board; if it is not erased, some kind of status register may be written.
            • eigma
              • Jan 2021
              • 13
              In a few days I will get access to SMD soldering equipment and try to remove the SPI chip.
              Until then, I spent some time understanding SPI flash dump file format, and comparing to the clean genuine firmware file downloaded from Samsung (T-MXL1JAUSC.bin). From sboot/src/MSDecompress.c we see there is a header at 0x20000 including a CRC32. The CRC32 algorithm seems unusual, not compatible with standard Python zlib.crc32. After more searching, I find Chakra3_017a0d6_20170731/scripts/BinIDPackFiles_Compress.py which gives the correct CRC32 algorithm and much more information about the file format.
              And indeed, the clean firmware from Samsung has good CRC:
              Code:
              $ ./spi_crc.py T-MXL1JAUSC.bin
              At 0x20000:
              00000000: 80 00 02 00 00 00 20 00  73 80 39 00 F3 80 1B 00  ...... .s.9.....
              00000010: 00 00 00 00 56 E2 50 B5  00 00 00 00 00 00 00 00  ....V.P.........
              u32ROM_START: 0x00020080
              u32RAM_START: 0x00200000
              u32RAM_END:   0x00398073  (len 0x198073)
              u32ROM_END:   0x001b80f3  (len 0x198073)
              u32CRC32_SW:  0xb550e256
              CRC:          0xb550e256  GOOD
              while my reading from SPI flash does not!
              Code:
              $ ./spi_crc.py samsung-un40h5003af.bin
              At 0x20000:
              00000000: 80 00 02 00 00 00 20 00  25 66 38 00 A5 66 1A 00  ...... .%f8..f..
              00000010: 00 00 00 00 EB 54 7C 3A  00 00 00 00 00 00 00 00  .....T|:........
              u32RAM_END:   0x00386625  (len 0x186625)
              u32ROM_END:   0x001a66a5  (len 0x186625)
              u32CRC32_SW:  0x3a7c54eb
              CRC:          0xe6632d3d  BAD!​
              I am still hoping to find a clean T-MXL1AUSC.bin (version 1005) for my device. But until then, I might try flashing T-MXL1JAUSC and hope for the best.
              • eigma
                • Jan 2021
                • 13
                Ha! I was using flashrom 1.4.0.. but seems there have been changes. I built flashrom from Git (~v1.5.0-rc1), I think this brings better support for WP (write protect) features of the chip, and was able to program the flash (despite the "Protection mode: hardware"...)!
                Code:
                $ ./builddir/flashrom -p ft2232_spi:type=2232H,port=B,divisor=100 -c W25Q32FV --wp-status
                flashrom v1.5.0-rc1 (git:v1.5.0-rc1) on Darwin 23.6.0 (arm64)
                Protection range: start=0x00000000 length=0x00400000 (all)
                $ ./builddir/flashrom -p ft2232_spi:type=2232H,port=B,divisor=100 -c W25Q32FV -w ../T-MXL1JAUSC-4mb.bin
                Updating flash chip contents... Erase/write done from 0 to 3fffff
                Verifying flash... VERIFIED.
                This image, maybe due to model mismatch, maybe something else, behaves differently, more output!!
                Code:
                 SPI BOOT
                 Console Initial OK
                65
                0055
                BIST_0 PASS.
                 MIU Initial OK 0328
                ASSERT: core/api/msAPI_Flash.c 388
                ------ stack backtrace ------
                5A5AA5A5
                Exception: 6
                r0 : 00000000  r1 : 00598AD4  r2 : FFFFFFFD  r3 : 00000009
                r4 : 00598993  r5 : 90000000  r6 : 90000005  r7 : 0000000A
                r8 : B0000F78  r9 : 003992BB  r10: 5A5AA5A5  r11: 003C0000
                r12: 00543082  r13: 000000BB  r14: 00540000  r15: 00000000
                r16: 000000B0  r17: 0019806D  r18: FFFFFFA7  r19: 8671011D
                r20: 60291913  r21: FFFF015A  r22: 606C9C0A  r23: 0034E613
                r24: 00560000  r25: 00000016  r26: 003DEF16  r27: 00000000
                r28: A0200000  r29: 00540000  r30: 02100018  r31: 00000004
                sr : 0000821F  pc : 003992AD  eear: 5A5AA5A1
                398768
                Exception: 6
                r0 : 00000000  r1 : 005989A4  r2 : FFFFFFFD  r3 : 00000007
                r4 : 00598863  r5 : 90000000  r6 : 90000005  r7 : 0000000A​
                Chakra3 does contain core/api/msAPI_Flash.c but line 388 is wrong. Must be a different version. I may reverse engineer the AP code to see what's the ASSERT.
                Call out, anyone who has T-MXL1AUSC.bin or knows how to obtain it, please help!
                • lotas
                  • Jan 2016
                  • 4741
                  • Russia
                  Look at this firmware, it looks like it's for Korea... (​T-MXL1JAKRC)
                  • eigma
                    • Jan 2021
                    • 13
                    Okay, wow, I think I got it. It was a single bit flip in the SPI flash. Details below:
                    After confirming I could compute the CRC correctly, I thought most of the flash dump looked valid, so there must be only some very small corruption. Maybe it was a single bit. (I have seen this before on a cheap WRT54G router) So I wrote a script to brute-force every possible bit flip, and check CRC, it took 18 hours, and found one:
                    Code:
                    $ venv/bin/python3 spi_crc_brute.py samsung-un40h5003af.bin | tee spi_crc_brute.log
                    At 0x20000:
                      4%|████▍                       | 70265/1599013 [49:37<17:55:48, 23.68it/s]
                    byte 0x000a507f bit 4: 0x3a7c54eb  GOOD
                    then produced a new file samsung-un40h5003af.bin-flip, flashed it, and it worked!
                    Code:
                    $ diff -u <(hexdump -C samsung-un40h5003af.bin) <(hexdump -C samsung-un40h5003af.bin-flip)
                    --- /dev/fd/63 2024-11-24 13:54:35.598092212 -0500
                    +++ /dev/fd/62 2024-11-24 13:54:35.594092165 -0500
                    @@ -37170,7 +37170,7 @@
                    000a5040 d3 c6 71 31 00 1b c7 ac 12 96 cf ea 40 fe ea 1d |..q1........@...|
                    000a5050 56 b0 6a b6 df ce 2c 16 f0 d7 9e 61 05 ab aa 60 |V.j...,....a...`|
                    000a5060 90 68 e0 ff ae 60 51 ab 8e f2 7f ff c1 e8 57 6d |.h...`Q.......Wm|
                    -000a5070 67 90 a8 e1 ff de c3 e8 54 2d b0 51 f4 e5 2f b5 |g.......T-.Q../.|
                    +000a5070 67 90 a8 e1 ff de c3 e8 54 2d b0 51 f4 e5 2f a5 |g.......T-.Q../.|
                    000a5080 d9 28 8e 64 d0 1f f7 f8 4b d3 6c 14 bd f8 4b 11 |.(.d....K.l...K.|
                    000a5090 8c 4e 65 03 83 fe d8 cb 5f ea c1 e8 54 8a 0c fa |.Ne....._...T...|
                    000a50a0 63 19 ff 17 9b 75 33 93 57 ec 29 45 0d ff d7 cb |c....u3.W.)E....|
                    Click image for larger version  Name:	IMG_2457.jpg Views:	0 Size:	160.2 KB ID:	3514243
                    UART output on power up, into standby:
                    Code:
                     SPI BOOT
                     Console Initial OK
                    65
                    0055
                    BIST_0 PASS.
                     MIU Initial OK 0328
                    Can not find good RRT block!!
                    Error: Load RRT5 setting failed
                    MApp_DB_Factory_Init() at 70
                    MApp_DB_Factory_Init() end at 73
                    DATABASE_TOTAL_SIZE=1D952MApp_DB_CH_Init()
                    MApp_InitVChipRegion5!
                    Reload Period: 2 ms
                    TOTAL_USAGE_FLASH_BANK_NUMBER    size = 7
                    QUICK_DB_GENSETTING_BANK     start @ 0x3A, size = 131072
                    SYSTEM_BANK_DATABASE1       start @ 0x3C, size = 131072
                    SYSTEM_BANK_DATABASE0   start @ 0x3E, size = 131072
                    SYSTEM_RRT5_BANK0      start @ 0x37, size = 65536
                    SYSTEM_RRT5_BANK1      start @ 0x37, size = 65536
                    GENSETTING       start @ 0x00E7A000, size = 4828
                    MODE_SETTING     start @ 0x00E7E004, size = 1920
                    RF_CH_START_ADR     start @ 0x00E7E784, size = 2300
                    RF_CH_AIR_START_ADR     start @ 0x00E7E784, size = 2415919104
                    AIR_VIR_CH       start @ 0x00E7F080, size = 53053
                    AIR_CH_SETTING   start @ 0x00E8BFBD, size = 5420
                    CATV_CH_SETTING  start @ 0x00E9A426, size = 5420
                    DATABASE_TOTAL_SIZE  , size = 121170
                    RRT_DESCRIPTOR   start @ 0x00EAF93C, size = 47250
                    RRT_SETTING      start @ 0x00EBB1CE, size = 2520
                    Database Usage Status :
                    sizeof(MS_GENSETTING)                   = 4828
                    sizeof(ModeInputModeType)*MAX_MODE_NUM  = 1920
                    sizeof(MS_VIRTUAL_CHANNEL)              = 53
                    sizeof(MS_CHANNEL_SETTING)x2            = 10840
                    Total Database >> used = 55634 , free = 9902
                    Keypad Initialize OK
                    MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
                    MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
                    [_MDrv_PNL_Init_LPLL][295]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
                    [_MDrv_PNL_Init_LPLL][297]u16HTotal=2200,u16VTotal=1125,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1125, u16DefaultVFreq=600
                    [_MDrv_PNL_Init_Output_Dclk][340]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
                    [_MDrv_PNL_Init_Output_Dclk][342]u16HTotal=2200,u16VTotal=1125,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1125, u16DefaultVFreq=600
                    [XC,Version] 00442327
                     MApi_XC_Init, 537, pXC_InitData->stPanelInfo.eLPLL_Type=1
                    MDrv_WBLE_EnableBLE(): invoking Hal_WBLE_set_ble()
                    PACLK:0xF006
                    PACLK:0xF006
                    PACLK:0xF006
                    [GOP_ALL, PID 0][Driver Version]: 0880, BuildNum: 4880, ChangeList: 2147483647
                    First GOP driver instance, flush GWIN HW
                    [HAL_TSP_CPU_SetBase][2167] load firmware (address, size) = (0x0056CD00, 0x00002A28)
                    firmware 111 0x0056CD00 0x00000000 0x0000AD9A
                     g_u8DCOnOff = 55
                    POWERON_MODE_SAVE >>
                    should go to standby!!!!!
                    Power down
                    MDrv_Power_ExecutePowerDown
                    => StandBy
                    ===DevNtp7414sByteWrite fail !!  Address 0x56CB9E===
                    ===DevNtp7414sByteWrite fail !!  Address 0x56CBA2===
                    UART output for full power on (pressing TV remote 'Power' button):
                    Code:
                    SPI BOOT
                    Console Initial OK
                    65
                    0055
                    BIST_0 PASS.
                    MIU Initial OK 0328
                    Reload Period: 2 ms
                    PACLK:0xF006
                    PACLK:0xF006
                    PACLK:0xF006
                    DSP code loaded successfully
                    Auth OK
                    ===== Check Audio Decoder Protection from hash-key IP =====
                    Hash-key Support DD.
                    Hash-key Support DD+.
                    Hash-key Support Generic HE-AAC !!
                    Hash Key Check DDCO Fail, No DDCO license!!
                    Hash-key Support DTS DMP.
                    Hash-key Support WMA.
                    Hash Key Check DRA Fail, No DRA license!!
                    Hash Key Check DTSLBR Fail, No DTSLBR license!!
                    ===== Check Protection IP End =====
                    ===HacI2cWrite fail !! Address 0x1===
                    ===HacI2cWrite fail !! Address 0x2===
                    ===HacI2cWrite fail !! Address 0x0===--AUDIO_SURROUND_SRS_TSHD--
                    [GOP0, PID 0][Driver Version]: 0088, BuildNum: 0488, ChangeList: 2147483647
                    gop_stretch: u16Pitch = 384, u16Width = 372, u16Height = 133
                    >Load Code...
                    >INTERN_ATSC Code...
                    >Verify Code...
                    >DSP Loadcode done.unsupport N51 FS compress
                    Reload BKSV: 0xAB
                    Reload BKSV: 0x8
                    Reload BKSV: 0x5C
                    Reload BKSV: 0xDB
                    Reload BKSV: 0x5C
                    delay should be great than 20ms.
                    RTC not init DB_CH: u8DataBaseBank=0
                    DB_CH: Erase bank=0x3E
                    msAPI_MIU_QuickDataBaseErase, dst=0x3E0000
                    msAPI_MIU_QuickDataBaseErase, dst=0x3F0000
                    HAL_SERFLASH_BlockErase (0x0000003F, 0x00000040, 0)
                    DB_CH: s_DB_CH_u32WriteTime=0x1
                    DB_CH: Write Done~ use 379ms
                    Warning: Someone want enable WP, but another one is in use!(0x2)
                    I have attached the recovered firmware file samsung-un40h5003af.bin-flip. I guess this should be pretty similar to the genuine T-MXL1AUSC.bin, but I don't know for sure, be careful if you decide to use it on your device!
                    • lotas
                      • Jan 2016
                      • 4741
                      • Russia
                      Well done! Here are two clean dumps, one for the programmer, the second, which is smaller for usb, you just need to rename it to T-MXL1AUSC.bin
                      • eigma
                        • Jan 2021
                        • 13
                        Some handwritten notes for main board power circuit.
                        • missyy
                          • Apr 2025
                          Trawling for info on "Eden" I was surprised to encounter a familiar name from my past life frequenting Foulab. It must be a small world for the handful of people interested in these chips.
                          Congratulations on the successful diagnosis and repair, and thanks for the writeup. I have a couple MSD3393 boards and--for a firmware reversing/hardware hacking novice like me, at least--this thread is an enormous help in figuring them out.
                          • Digitek
                            • Feb 2019
                            • 5
                            • México
                            Greetings.
                            Could you share the script you created for this purpose?
                            I've tried to do it in C# based on what you posted, but I can't get the result you show.
                            • eigma
                              • Jan 2021
                              • 13
                              Code:
                              #!/opt/homebrew/bin/python3.11
                              import sys, struct, zlib, hexdump, tqdm
                              import crcmod
                              CRC32 = crcmod.mkCrcFun(0x104C11DB7, 0, 0)
                              data = bytearray(open(sys.argv[1], 'rb').read())
                              print('At 0x20000:')
                              header = data[0x20000:0x20020]
                              hexdump.hexdump(header)
                              print()
                              u32ROM_START, u32RAM_START, u32RAM_END, u32ROM_END, _, u32CRC32_SW = \
                                struct.unpack('<6L', header[0:0x18])
                              print(f'u32ROM_START: 0x{u32ROM_START:08x}')
                              print(f'u32RAM_START: 0x{u32RAM_START:08x}')
                              print(f'u32RAM_END:   0x{u32RAM_END:08x}  (len 0x{u32RAM_END-u32RAM_START:06x})')
                              print(f'u32ROM_END:   0x{u32ROM_END:08x}  (len 0x{u32ROM_END-u32ROM_START:06x})')
                              print(f'u32CRC32_SW:  0x{u32CRC32_SW:08x}')
                              print()
                              for byte in tqdm.tqdm(range(u32ROM_START, u32ROM_END)):
                                for bit in range(8):
                                  data[byte] ^= (1<<bit)
                                  crc = CRC32(data[u32ROM_START:u32ROM_END])
                                  if crc == u32CRC32_SW:
                                    print(f'byte 0x{byte:08x} bit {bit}: 0x{crc:08x}  {"GOOD" if crc == u32CRC32_SW else "BAD!"}')
                              • Digitek
                                • Feb 2019
                                • 5
                                • México
                                Code:
                                import crcmod
                                print()
                                print()
                                data[byte] ^= (1< crc = CRC32(data[u32ROM_START:u32ROM_END])
                                data[byte] ^= (1<
                                Thank you so much.
                                I finally understood the meaning of the 20 bytes at offset 0x20000
                                • Takeatry
                                  Yet another Samsung QLED Boot Loop
                                  by Takeatry
                                  Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                  10-04-2024, 02:57 PM
                                • torchzack
                                  Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                  by torchzack
                                  Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                  I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                  Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                  08-28-2023, 07:42 AM
                                • NolesFan
                                  Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                  by NolesFan
                                  Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                  10-24-2024, 06:36 PM
                                • blaster_
                                  Samsung UE49MU6105K - boot loop, horizontal lines
                                  by blaster_
                                  Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                  Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                  06-22-2022, 05:19 PM
                                • signedupfordownload
                                  Samsung UE49KU6500U boot loop
                                  by signedupfordownload
                                  My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                                  With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                                  I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                                  07-29-2024, 01:56 PM
