Sony Bravia KDL-40EX400 dead
  • suiramix
    • Mar 2011
    • 131
    Back in April, I was asking for some help in regards of Sony KDL40-EX400 LCD tv with no power up (dead set) by pressing the remote or tv set power button. The power supply board G2HE had only [STBY 3.3V] = 3.31V and and [AC OFF DET] =0V and everything else is 0V.
    In the meantime, I did order and replaced IC6301 (Sony CXA3809M), but no joy , same result. Now at connector CN6101 the voltage are:
    pin 1 [STBY 3.3V] = 3.30V
    pin 2 [AC OFF DET] = 2.80V
    pin 3 [POWER ON] = 3.21V
    pin 10[BL_ERR] = 3.30V , and everything else is 0V.
    According to training manual CTV61 , “dead set” condition is possible due to loss of REG12V , but not explain how to troubleshoot it! So what else should be defective?
  • JUCaESAl
    Sony bravia KD-65AF9
    by JUCaESAl
    Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
    Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
    10-20-2025, 04:03 AM
  • PopsCaps
    Sony Bravia KDL-40V2500 that will not power on
    by PopsCaps
    I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
    I do not hear any sound and I cannot see any backlight.
    I have tried disconnecting every cable on each board one at a time to see if anything changes.
    The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
    My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
    03-25-2025, 11:23 AM
  • alegatorul
    sony bravia kdl-43w756c, no power, no sound
    by alegatorul
    the charger brick has 19,2-19,3 vcc
    changed the inverter board same result.
    where should i start?
    cheers
    11-15-2025, 10:00 AM
  • justin35
    Sony bravia kdl-43w755c - boot loop
    by justin35
    i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
    from what i read online it looks to be an emmc issue…
    i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
    i took out the board and say an samsung 16gb emmc
    i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
    i could try to put one instead of the 16gb one, but will it work?
    where do i get the software from?
    any help will be much appreciated!...
    03-06-2024, 12:26 PM
  • thstuff
    Sony OLED XR-77A80J - Initially dead, now 4 Flashes
    by thstuff
    A) TV initially dead
    B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
    C) Was able to perform a Reset from Settings menu and completed out of box configuration.
    D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
    E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
    12-26-2024, 09:10 PM
