panelook com for lcd panel LM270WQ1-SDB1 pdf
  • bammbammfran
    • Apr 2014
    • 476
    Hi all
    Does anyone out there have a paid membership to panelook.com
    I am looking for LCD screen panel pdf and I do not want to pay $800 for a year !! for a few pdfs
    That or another source that isn't outrageously priced.
    Re: panelook com for lcd panel LM270WQ1-SDB1 pdf
    Oops, wrong post, never mind.
      • 31250
      Originally posted by bammbammfran
      Hi all
      i dont know what you want to know, but theres lots of data here:
      http://www.lcdsolar.com/products/Pro...WQ1-SDB1/31896
        Have a look at my Panels database, which doesn't have them all but has a lot:
        http://www.toms-service-manuals.com/...h=Submit+Query
        (I got sent a disc from a friend in China, they regularly sell them in the markets for a few pounds each.)
        • bammbammfran
          • Apr 2014
          • 476
          thanks guys, but I need the LM270WQ1-SDB1
          I have the LM270WQ1-SDA2 and the SDB3 and the SDf1, SLB1 and SDE3 ones, but they all have some serious differences in their wiring at the lvds connectors
          they have anywhere from the standard 30 pin plug up to a 51 pin plug. some screens use two plugs
          I am trying to do some reverse engineering on the 27" apple leds
          the SDB1 is in the cinema display 27" and the SDB3 is in the 27" thunderbolt version
          The Imacs probably use even different versions
          • ted212
            • Aug 2016
            • 9
            • norway
            Hei I need pdf for SDB3 modell. could you please share it.
            • bammbammfran
              • Apr 2014
              • 476
              This should be it.
              GOOD LUCK with it !!
              • ted212
                • Aug 2016
                • 9
                • norway
                Hi , thanks:
                but this is not the schematic, its just an data sheet, you cannot see the components and schematics.
                • bammbammfran
                  • Apr 2014
                  • 476
                  Sorry, that is all I have on it.
                  I doubt that you will find an actual schematic for it.
                  FYI: most issues on these is with the led lights and sometimes, the T-con board.
                  • ted212
                    • Aug 2016
                    • 9
                    • norway
                    ok thanks anyway
                    • howardc64
                      LG 49UJ6500 LCD panel lighter band that goes away
                      by howardc64
                      49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                      Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                      02-19-2023, 12:13 AM
                    • triplefour
                      SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                      by triplefour
                      TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                      tcon is built into mainboard.
                      Only one cable goes to panel boards.
                      there is a cable from one panel board to the other that links them.
                      cost cutting measure that results in us having harder time to diagnose.
                      removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                      used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                      07-28-2022, 07:59 PM
                    • Storyteller12
                      QN55Q60R Service Menu Panel Help
                      by Storyteller12
                      I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                      I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                      I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                      the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                      01-13-2024, 01:57 PM
                    • maneatingmonkey
                      Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                      by maneatingmonkey
                      I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                      There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                      03-27-2024, 07:17 AM
                    • howardc64
                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                      by howardc64
                      • Prior owner tried a replacement main board. No difference.
                      • Samsung 2x red blinking standby LED = panel fault
                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                      07-19-2025, 10:54 PM
