I've got the famous LG-Philips master-slave inverter (6632L-0470A) with no backlight, not even an attempt to strike the backlight or a 2sec to black symptom. In my case, a blue LED lights up on master then goes out slowly. Disconnecting the slave results in no LED and no backlight either.
Wondering what the purpose of this LED is.
So far I've noticed no gate waveforms to the FETs and the CT voltage does not oscillate as I would expect.
I do have some IC function the Duty Out is working as is the respective oscillator and onboard Vreg voltage.
24V and BLON are present, DIM PWM has a square wave, DIM waveform changes as TV boots.
Have already swapped BD9897FS as I suspected this to be the cause but to no avail.
Anyone have a working set remember what the LED should do when the inverter works? Or some documentation on it?
TV: Philips 42PFL9632D
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
