Sony KD-49XF809y doesn't turn on
  • Zetabeta87
    • Nov 2024
    • 7
    • Italia
    Hi everyone!
    I have a 2018 Sony kd 49XF8096 that suddenly stopped turning on: No LED lights up, and it doesn't respond to the power button or the remote control.
    The power supply delivers 19.45vand I simply tried to check the fuses on the 2 boards (power and main) but everything seems ok. I have no references on where to test the voltage, but somewhere on the mainboard I also detect some, so you can't to understand which card may be to blame.
    Can anyone give me some advice? I haven't found anything online
    Thanks so much!!!
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    Hi!
    Do you get a standby light? I would start by checking if the PSU outputs 19.45v when it is plugged into the board, from the connector on the small power PCB.
    Next If it is present I would check the voltage on those 3 inductors, the grey box looking things on the small PCB
    • Zetabeta87
      • Nov 2024
      • 7
      • Italia
      No, none of the LEDs light up. I checked and the voltage even when connected remains at 19.4v (connector pin under the PCB).
      Testing inductors pin to gnd I get, respectively each pin: 19.4-19.4v, 19.4-19.4v and 12.5-6v (lower-right one, near the writing).
      • Zetabeta87
        • Nov 2024
        • 7
        • Italia
        I haven't found the solution yet, without intervening on the card I'll replace it and I'm thinking about the mainboard but I'm not sure it's the one, does anyone have any advice?
        • zomi
          • Nov 2011
          • 512
          Most likley the main board.. emmc gone..
          You can check for voltages around the emmc .. they should be there.. but corrupted emmc not letting it work
          • Abel Bejan
            Sony Vaio does not turn on, overheats
            by Abel Bejan
            I am quite noob in advanced electronics, however I'm trying to fix a Sony Vaio PCG-71211M laptop mainly because I love old hardware. I don't want to send it to a technician because this computer is not important for me, I want to fix it as a hobby.
            Shortly, this laptop does not display any video output when turned on, no POST, nothing. The keyboard leds are on and I can actually turn Num Locks on and off. Sometimes the laptop turns itself off straight away, sometimes, mostly after some attempts, the laptops enters a loop in which the cpu fan spins very aggressively and the CPU,...
            01-11-2025, 10:11 AM
          • odie34
            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
            by odie34
            I am a hobbyist (not a professional) so please be gentle...
            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
            02-18-2024, 09:11 AM
          • pajdek
            Lenovo Y700-17ISK turn on and off
            by pajdek
            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
            09-20-2023, 02:49 AM
          • Highvoltagerchelie
            Sony XBR-65Z9D won't turn on after lighting strike
            by Highvoltagerchelie
            Good afternoon. I found this forum as I was looking for troubleshooting information for my Sony z9d. A lightning strike hit very close to the house and did nearly $30,000 in electronics damage. The TV appears completely dead with no status light and no picture. I found the Sony XBR-65Z9D service manual and followed the troubleshooting steps on Pages 21-26. All checks seem normal except DC_OFF_DET check on Page 23 R420 voltage was slightly higher than 3V. It was 3.475V and C418 was slightly higher that the 5V at 5.3V.
            I proceeded to check the Power Board CN6401 connector. With all...
            View and Download Sony XBR-65Z9D service manual online. GN2TR CHASSIS. XBR-65Z9D lcd tv pdf manual download.
            11-30-2023, 04:49 PM
          • Dreamcazman
            Sony KV-XJ29M31 CRT TV - Very dim image on turn on
            by Dreamcazman
            Hi all, I recently picked up a Sony KV-XJ29M31 CRT TV (BG3R chassis, Australian model) cheaply & completed the RGB mux mod on it for some retro gaming. That worked great, however, I have another problem which I hope someone can help me with or at least steer me in the right direction.
            Basically, the issue is when it's cold, it takes a while (like 2 mins) for the picture to come up. I think the image is there, it's just very dark or dim. I can hear the degaussing sound & I can change inputs & hear audio but no image.
            Once it's running properly, it keeps...
            02-28-2022, 07:47 PM
