Hitachi 55HDT51 questions.
  • Shinju
    • Mar 2014
    • 1239
    Hey all
    I got one of these massive beasts for super cheap, seems to work great, has a good picture for a 720p and an early plasma.
    Question 1
    When the Panel is on for 15+ hours a pixel wide faint blue line shows up on the left hand side of the screen vertically halfway down the panel. Anyway after changing the input a few times it would go away and has yet to come back. Would the AV/HDMI input box have some baring on this affliction?
    It doesn't seem like the typical IC issue but I am still pretty green on Plasma's I did the toothpick deal and gently rubbed the ribbon cable but nothing changed. I have been using this Panel non stop for the last 2 days and it has yet to return.
    Question 2
    I have the original remote ect, how does one get into the hidden service menu on a Hitachi Plasma? I want to see how many hours this monster has on it.
    I have to say for a retail price of 10k its got all the bells and whistles, the built in audio system is probably one of the best I have heard from a TV.
    Thanks!
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
  • wolf1976
    hitachi 50hk5600 problem with display
    by wolf1976
    hi
    i have the above tv and the display starts distorts the display at only in applications like you tube
    after and on the didital channels
    now without connect the antenna only the image of itsselfs tv i have the image i have in attach
    i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
    can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
    09-13-2025, 02:26 PM
  • massimomax
    Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
    by massimomax
    Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
    spero che qualcuno può averlo per riprogrammare eprom. grazie
    Post in English !!!
    I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
    02-28-2025, 07:27 AM
  • dragometin
    Hitachi 40HYC42
    by dragometin
    TV Model: Hitachi 40HYC42
    Power Supply: 17IPS71
    MainBoard: 17MB95M
    Panel: VES400UNDS-2D-NO3
    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
    Is there any variants on 17IPS71 power supply's?
    UART output pins 10 and 12 on scart connector:
    Code:
    12:24:04.595
    08-08-2024, 05:53 AM
  • sotodefonk
    Help finding the correct model of a T-Con board on my Hitachi TV
    by sotodefonk
    Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
    I opened the tv to access the board and took the shared pictures of the T-Con board.
    I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
    I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
    Inspecting...
    06-28-2024, 04:39 PM
