Bose Lifestyle 650 remote malfunction
  • hzwg88
    replied
    very thankful
  • mpa2
    replied
    Here you are!
  • hzwg88
    replied
    Can you provide a nvram? Thank you
  • mpa2
    replied
    Well, I've found another remote, which worked without any issue. So no problem on the receiver side.
    I then reprogrammed the nvram of the broken one with the dump from the new one - now my friend has two functional remotes. The first thought is often the right one
  • mpa2
    replied
    Yes, harmony remote doesn't have a feedback.
    I monitored today the activity on the spi interface between the transceiver and the mcu. Sometimes you can see some activity after a key press, sometimes not.
    Could not find a system behind it.
    I'll try to find another remote for testing.
  • Diah
    replied
    Originally posted by mpa2
    I would still expect some output on the display. The RC behaves erratic, thus I asked about a known working firmware dump for testing.
    I don't have another original remote, but with my harmony elite I can control the main unit without a problem.
    yours harmony elite with out screen to sync feed back !! so how you put this in compare.... or i am wrong ?
  • mpa2
    replied
  • Diah
    replied
    i think the issue at main unit transmitter didn't send sync feed back to RC so display didn't show any sign.. and it go to sleep look like it turned on with out any main unit closed to it
    any other RC under hand?
  • mpa2
    replied
    The push button for backlight is here
  • Diah
    replied
    You mean the push button itself?
    just remark it on yours photo which it show all BL working with out pressing any key
  • mpa2
    replied
    Originally posted by Diah
    can you show it here with focused clear photo
  • Diah
    replied
    Yes, after removing the white foil I tested all keys - they are all NO and closing every single one of them causes a wake up. The current draw looks fine for me - about 5 ma on start up, about 3 ma when awake and almost zero when asleep.
    I noticed another strange behavior. There a light switch on the buttom side, which turns on LED Backlight of the keypad and also wakes up the MCU. This wakeup works always, the LEDs however sometimes don't react.
  • mpa2
    replied
  • Diah
    replied
    Im monitoring the current draw with the lab psu and in addition the mcu sleep/awake state with thermal imaging.
    and did you noticed some unusual draw? by the way did it wake up on all keys
  • mpa2
    replied
    this is not enough.. you need to put yours DM in Amp reading in the Red + line and switch on..... remark the pulling of Am at any state even sleep and when you wake it ab
  • Diah
    replied
    Unfortunately, this didn't have any effect. All contacts are clean and open. Still the same behavior.
  • mpa2
    replied
  • Diah
    replied
    Thanks, I will try it tomorrow. I actually tested the frequently used keys and the reaction of the MCU (wake up) was adequate, but I didn't check all of them. I hope I'll get this white stuff off without damaging it.
    its glue as Mobile glass protection screen
  • mpa2
    replied
  • Diah
    replied
    you have one or more keys always in contact..... carefully remove the white keys plate use alcohol up to 90% , clean the conductive lines all with it too let it dry and align the keys sheets back
  • FALKLAN
    Mercedes-Benz W163 Bose Audio System
    by FALKLAN
    Howdy everyone!
    I have a SUV with a Bose audio system and I'm considering either a system upgrade, or purchasing a complete replacement system while bypassing the integrated Bose system.
    On the Bose side, I have not found any specifications yet. It's a decent system but I'm, at a minimum, replacing all the factory speakers, head unit and adding an amp and two 8" subs. The Bose is a 2ohm system and I'm not certain about this point. In order to use a 4ohm set of speakers (component/loud), I would need to install 2 sets of 4ohm speakers wired in parallel to match the...
    12-07-2023, 11:22 PM
  • cstout
    DeLonghi AC Remote only accepts 3V
    by cstout
    Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
    The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
    I can't find any schematics...
    06-03-2024, 03:53 PM
  • Mc_Millian
    Toshiba 50lf711u20 fire tv remote not pairing
    by Mc_Millian
    I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
    The Tv model number is: 50lf711u20 Rev B.
    I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
    I've tried 3 different remotes which should be fully compatible with this TV.
    Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
    The power button, along with the volume,back,select, and directional...
    04-07-2022, 12:15 PM
  • edugimeno
    HiSense 55A7500F won't obbey to remote after power on
    by edugimeno
    Hi! I have this TV set that does the following:
    1) I press the red power button on the remote
    2) The TV turns on normally
    3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
    4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
    Then after it's off, it would again accept the TURN ON from the remote and same again
    BUT:
    -The remote does show the correct IR beam while observed thru a phone camera
    -The TV works fine while using the MiRemote...
    03-14-2023, 11:22 AM
  • tmhobadcap
    Pioneer VSX-522-K remote control not working???
    by tmhobadcap
    I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
    At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
    12-24-2020, 01:44 AM
