led tv 32''.
  • willyam1
    • Feb 2012
    • 112
    • israel
    led tv 32''.
    hi.
    in the first the problem was backlight for sec then off.
    the power supply board is cvb32005 all capi ok all voltage ok exept the voltage to the led backlight that go high to about 80v and then go down to about 25-30v.
    the source of this voltage is IC OB3350CP AND A FET AND CIOL AND DIODE its similar to pfc circle after checking all voltages and resi diode the backlight stop working.
    i dismantel the panel to check the led strips.
    ther 3 lines in parrlel each line with 9 leds.
    i present an ext supply of about 5v to each led and i found in each line a 3 led that not lighting when supply is present to each led seperet.first were can i find this kind of leds ? AND IS IT POSIBEL that the high voltage from the power supply of 80v-100v could damage them? what is voltage that this led should light?.
    thanks willyam
  • dcapper
    • Dec 2013
    • 496
    Re: led tv 32''.
    Can you post pics and the make and model please?
    • willyam1
      • Feb 2012
      • 112
      • israel
      Re: led tv 32''.
      sorry the tv is luxor model lh32s83w sorry cant put pics my phon is broken
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
        I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
        https://www.ebay.com/itm/116497313155?var=416785404161
        Here are some of the description from the eBay seller
        The main parameters:
        1. Product name: High-power non-isolated DC boost module power supply.
        2. Product model: 100A2000W.
        3. Input voltage: DC12V-60V.
        4. Input current: 100A (maximum)....
        05-18-2025, 09:45 AM
      • Jembang
        coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
        by Jembang
        good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
        11-01-2024, 09:55 AM
        LM358 LM358S-13 Datasheet
        The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
        Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
        10-07-2024, 04:12 AM
        How to modify a switching power supply that has voltage/current adjustable but powering it from a battery pack
        I have been pondering this question for a while but now I have see if this doable but I need to answer this question once and for all
        I would like to know how to safely do this undertaking my first thought is to solder wires to the main filtering capacitors and see
        what voltage I am getting and seeing if I can build a battery pack with voltage or not and if
        I can find a BMS balancing protection board at this voltage level and weather or not do I have use more than one BMS balancing protection board...
        05-11-2025, 05:22 PM
