LG 50PG6010. Blown PSU replaced, then No Picture.
  • baddesley
    Engineer
    • Dec 2012
    • 55
    Hi Guys,
    I have an LG 50PG6010 50" Plasma, which I have had for over a year now and which has worked fine for all that time (once I'd replaced the four 3300mf caps on the PSU anyway).
    Recently though, it delveloped a fault with the PSU, failing to come on, but while trying to sort that out, the PSU blew up, taking the Y Sus with it.
    Initially, I replaced the PSU, which now works fine, all voltages present and normal, but I got no picture (sound OK). It was then that I found out that the Y Sus was faulty (a couple of blown FETs and a SM fuse at least), but rather than replace these, I bought a tested replacement board from the same people that I'd got the PSU from.
    However, despite it seeming to run OK (all fuses intact and all heatsinks running nicely warm, including those on the buffer boards), there is still no picture. The PSU runs quietly and the sound is fine. I tried to measure VY and VSC on the Y Sus board, but on DC 600V range (highest on my DMM), it goes off scale. Is this normal?
    The X Sus heatsinks are cool though, despite power being on the board and all FETs/Transistors and Fuses checking out OK (cold checks with DVM), so to my mind, this is not being driven at all - though my knowledge of plasmas is very limited (I'm an old-school ex - CRT TV & general Electronics Engineer).
    I have tried disconnecting the lower driver L & R boards, but no difference. Any ideas, as this is driving me nuts and I have not been able to get any circuit diagrams (downloaded the supposed service manual, but that has very limited low power only circuits).
    Any advice, ideas, or full circuit diagrams would be much appreciated. Thanks in advance.
  • baddesley
    Engineer
    • Dec 2012
    • 55
    Re: LG 50PG6010. Blown PSU replaced, then No Picture.
    Anyone? Any idea how to check my X Sus, if this could be the problem, of any other ideas? Sorry for posting again, but I really do need some help on this.
    • baddesley
      Engineer
      • Dec 2012
      • 55
      OK, well I have now fixed this with a nex X Sustain board (or is it Z Sus?), so it seems that can indeed cause no picture, though I've no idea what on the board was causing this, as everything seemed to check out OK.
      It would have been nice to have had some confidence in my decision before buying this though, as it's now cost me a fair bit in new panels. Not sure why I didn't get any replies to this (or either of my other posts!), maybe I've just been unlucky and asked questions about sets nobody knows much about.
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        glad to hear you got it fixed. some of these threads just don't get very many hits. tom has a very thorough post on how to diagnose plasma failures.
        Liberating magic smoke one part at a time
        • baddesley
          Engineer
          • Dec 2012
          • 55
          Thanks, I guess I've just been unlucky so far.
          However, I've now got another problem with the TV; purple on some highlights and some sparkling, which I've seen mentioned on here before on other sets. I've carefully adjusted VS and VA on the power supply, but this has just made it a lot worse. If I adjust VS up from the stated 195V to 200V, the problem is a lot less noticeable, but obviously, I don't want to leave it like this and the picture's still not right anyway.
          There are several adjustment pots on the Y Sus and one on the X Sus and I've tried gently 'rocking' these back and forward (and back again), but none make much, if any, difference. Obviously, I don't want to mess these up too much without having some way of measuring what I'm doing. Anyone have any info on setting these up?
          The service manual (very limited!!) mentions a set-up menu, but I haven't found how to get into this, as some of the keys it mentions on the remote are simply not there (could be a special service remote?). Anyone with any info on this, or other ways to sort this out?
          I have been very careful to get the correct version replacement boards, but these could need setting up/matching or could of course be faulty.
          Anyone got any ideas?
          • R_J
            • Jun 2012
            • 9633
            Those voltages are for a new panel, as the panel ages they may need to be adjusrted slightly, usually vs can be lowered by around 5volts and vsetup vsetdown can be adjusted for minimum speckles (the correct way is with a scope). but as the panel ages you can only do so much. Another thing is the control board may need new firmware (loaded on with a special jig) as for getting into the service menu, that wont help the speckles. and lg did use a special service remote.
            • baddesley
              Engineer
              • Dec 2012
              • 55
              Thanks RJ,
              Any idea what a safe maximum is for VS, as increasing this helps (reducing makes it worse, even the standard 195V produces the sparkles/tint on highlights). Unfortunately, I've no idea what VS was before I replaced the power (and other boards) - when the picture was perfect!
              • baddesley
                Engineer
                • Dec 2012
                • 55
                This is what I'm getting, though it's difficult to get a good image of what is happening (i.e., its actually worse than these photos show):
                This seems to be worse once the TV warms up. Has anyone got any idea what is causing this and what to adjust/replace to fix it? Is there a sequence to follow to adjust the various preset pots in the TV for instance (the picture was absolutely perfect before the Power boatd went and I had to replace this and the Y and X Sustain boards)? Thanks.
                  Check the -Vy voltage on the Y-sustain and the Vzbias voltage on the Z-sustain.
                  Compare voltages to panel sticker. Order is:
                  N.A. / -Vy / Vsc / N.A. / Vzbias
                  or rarely:
                  N.A. / Vsc / -Vy / N.A. / Vzbias
                  (the minus sign tells you which is -Vy)
                  • baddesley
                    Engineer
                    • Dec 2012
                    • 55
                    Thanks Tom, much appreciated, I'll have a go at that tomorrow. I did look for marked voltages before and couldn't find any, other than VS and VA, but I'll have another look tomorrow. Having a sequence should certainly help too.
                    • baddesley
                      Engineer
                      • Dec 2012
                      • 55
                      OK, well I tried to check and adjust these volages, but unfortunately my DMM will not resolve the Vsc and -Vy voltages (shows out of range), presumably due to the high frequency component, but I was able to adjust the Vzbias correctly. The bare voltages were listed on the panel, but there was no reference to which voltages they were, which is why I was unable to check and adjust anything before!
                      However, none of these made much of a difference, only VS made any difference and I have solved the problem (as far as I can tell) by adjusting this up to 205V (TV well warmed up, showing high brightness picture). This is far from ideal, as its supposed to be 195V, but it seems to be the only thing that fixes it - unless anyone has any other suggestions.
                      Thanks for your help anyway Tom, it gave me the confidence that my Vsc, -Vy and Vzbias are near enough correct. I just hope the set is still reliable with it set like this!!
                      • baddesley
                        Engineer
                        • Dec 2012
                        • 55
                        Unfortunately, not solved, but greatly improved; it only flares on a few high brightness/contrast scenes now. I am reluctant to increase VS further however, but if anyone else has any ideas, or can tell me what VS they have adjusted theirs to to solve this problem, they would be much appreciated. Otherwise, I think I'll leave it at that and put up with it for the sake of reliability. Thanks again to those that have helped.
                        • zlr8r
                          HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
                          by zlr8r
                          Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
                          To begin with, this laptop was dead-dead.
                          Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
                          • am getting white power led
                          • 5-long-flashes on CAPS Lock and NUM lock
                          • then, fan full speed
                          • CPU heats up some (smaller die PCH, does not)
                          • always constant black screen no matter what's tried
                          • no USB recognition
                          • no HDMI output
                          this is as far as I can get with it and not sure where to inspect next ?
                          I tried...
                          03-27-2024, 03:13 PM
                        • Tr0ll
                          by Tr0ll
                          Original T-con:
                          First replacement T-con:
                          10-07-2023, 07:48 PM
                        • JJAAMM
                          by JJAAMM
                          Problem
                          07-06-2023, 06:01 AM
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
                        • joesmoe91
                          Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
                          by joesmoe91
                          My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
                          02-22-2024, 07:38 PM
