Sound with no picture is the fault. Checked inverter board which is CPT 370WA03 Rev01 all transformers seem ok. Fuse F1 ( very small marked D) found to be open circuit whats the chance that it could be only the fuse at fault?
Goodmans LD3755HD inverter board fuse blown
Re: Goodmans LD3755HD inverter board fuse blown
Generally--summit Kills a fuse--what current do you read if you put ammeter across it and run the set?TELEFIX
Originally posted by Alastair E View PostGenerally--summit Kills a fuse--what current do you read if you put ammeter across it and run the set?
