Samsung GQ65Q60 QLED
  • lotas
    • Jan 2016
    • 4754
    • Russia
    These 2 legs will not rise, the case of the transistor will crack, the tracks on the board will break, then only use a hairdryer to completely remove it.
    • marillo
      • Sep 2024
      • 21
      well 1st one failed...
      this is tough to do... i should have tried fingernail lol
      i think it was too hot so it fell apart... but i couldnt get the pins up otherwise...
      so this was the same model with a broken panel, where i just did this test. i have the same tv with the not broken panel, just reboot problem, so i m not sure how will i manage this in order not to destroy everything...
      • marillo
        • Sep 2024
        • 21
        should i remove the remaining part as well... tried to turn it on.... same as before just boot loop
        • Diah
          • Feb 2013
          • 6439
          ohh my GOD... i can notice from yours test video, you have stable hand... but why so,,, to lift pins first need at soldering fat pasta on the pins... then add little solder.. then use shield to suck the solder it will be easy to remove..damage it can be replaced
          read the label of the MOSFET first in case you
          if this was the one we trouble shooting it then you have short inside the panel glass.. no way
          • lotas
            • Jan 2016
            • 4754
            • Russia
            Why bother touching it at all, if it was working, if you want to remove it from the board, then you need to use a hairdryer to remove SMD components, and not a simple soldering iron, as I wrote above, you will ruin it.
            • marillo
              • Sep 2024
              • 21
              nooo... this was not the one with trouble shooting of course... the videos i made with the one which panel is not damaged! i got one with broken panel, in order to check if the reason is the mainboard...
              the "good" tv is standing, and from that i took the measures. the bad one, with broken panel and now broken transistor is laying... so no damage caused (yet)
              • marillo
                • Sep 2024
                • 21
                well i m not sure if it was working? how do you know if i may ask? the tv was and iscin a bootloop... 🤷‍♂️
                • Diah
                  • Feb 2013
                  • 6439
                  the broken screen tv... even u remove Q totally will remain in bootloop because its broken and sure there are shorts at some where on glass
                  • marillo
                    • Sep 2024
                    • 21
                    alright, makes sense. so i will need to figure out how to remove the transistor properly. and can you tell me what will be then next step after i remove the two pins?
                    • Diah
                      • Feb 2013
                      • 6439
                      before this act.... take out the buffer boards from the broken one , and compare the testing on all parts one by one as diode mode for D and high Ohm for C direct on the parts also in reserve way..
                      • marillo
                        • Sep 2024
                        • 21
                        i checked yeaterday, before destroying this one... results seemed to be the same... and what wouod be tghe next step when i accomplish to separatenthe two pins? qould it work or anything else to do? i read also that some managed just by taping some part on the lvds cable?
                        • Diah
                          • Feb 2013
                          • 6439
                          don't move the Q., however i don't like to write over this forum any kind of masking.... as its not repair... but it could satisfied you some how.
                          try to mask exactly this pins start with Red mark... then yellow then blue tell the result.... all U ribbon cable should be in place
                          • marillo
                            • Sep 2024
                            • 21
                            i got a headache... it s such a sysiphus work... i didnt manage, nothing has changed. keeps going off and on. on one sec... off two seconds... than on sec... and so on... it s frustrating
                            • Diah
                              • Feb 2013
                              • 6439
                              scrap it what did you waiting for when panel shorted !!
                              • marillo
                                • Sep 2024
                                • 21
                                thanks for your help, time and effor. really appreciate it. may i ask whoch part of Germany are you from?
                                  Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                                  This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                  09-07-2024, 12:10 AM
                                • DennisKal
                                  Samsung QLED QN55Q80RAFXZA - No backlights
                                  by DennisKal
                                  Hi, I am working on a 2020 Samsung QLED QN55Q80RAFXZA Version FA02. On Christmas Day, the TV made an odd sound while off (in standby). After that it would not turn on. There was no red standby light.
                                  Based on what I read on the net, I ordered and replaced the Power Board, the Main Board and the LED Driver board with a kit from TVPartsToday. After these were installed, the TV would start up and play the startup tone but the screen was still dark. By shining a flashlight onto the screen, I could see the faint image that was on the screen as it was in the startup mode looking for...
                                  01-05-2023, 07:04 PM
                                  09-07-2024, 05:50 AM
                                • max789
                                  Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                  by max789
                                  Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                  I made the following tests:
                                  1. Disconnected the main board from Power Board = backlight works.
                                  2. Connected the main board and disconnected the T-Con = backlights does not work.
                                  So I ordered a main board from Ebay also BN41-02156A but from...
                                  01-18-2024, 06:56 AM
                                • Kaar3l
                                  Samsung QLED QE65Q7FNAT only standby light
                                  by Kaar3l
                                  TV: Samsung QLED QE65Q7FNAT
                                  PSU: BN4400940A
                                  MB: BN94-12832K
                                  I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                  09-24-2024, 01:35 PM
