Samsung GQ65Q60 QLED
  • marillo
    • Sep 2024
    • 28
    Dear all,
    I m new to this forum. I tried to sell my broken TV, which reboots constantly. And a guy told me that i could fix it somehow by taping some ports. I have no clue sadly how to do it and I am hoping someone can help me.
    My TV has the issue, when I turn it on it just keeps going off and on. I dont see any Samsung logo.I just see the LED backlights on and off. When I disconnect the ribbon cable, which connects the mainboard to the TV panel. The LED backlights stay on.
    Is there someone who can help with this particular TV. I can post pictures, and videos later?
    Thanks in advance!
  • Diah
    • Feb 2013
    • 6501
    let start to agree on correct name of parts to avoid any mistake... the cable you disconnected between the Main Boards and the panel module called LVDS. yours LED BL come on it mean there are issue on the panel..
    take out the speaker and if there metal plate cover the panel buffer boards take it out too... you will be able to see U ribbon cable ( flat cable connect 2 half of panel side together one on the the left side and one on the right side.... LVDS keep them connected.... and just disconnect one of these U ribbon one a time on the right side and turn on... take look on the screen if it display some things.... do the same test on the other side..
    you can upload photos of the buffer boards over here too and the screen result too.
    • marillo
      • Sep 2024
      • 28
      Thanks Diah. Attached a video. This is the situation when the LVDS is connected to the main board. It just goes on and off. The other two U ribbon cables are disconnected!
      • marillo
        • Sep 2024
        • 28
        and when i disconnect the LVDS cable the backlight stays on
        • Diah
          • Feb 2013
          • 6501
          post clear photos on the panel buffer boards the left and right... so you will have 4 pieces
          • marillo
            • Sep 2024
            • 28
            here are the pics. ihope thats what you mean? the lvds cable is currently disconnected. and also the two, U ribbon cables as well. with this configuration the led backlight stays on.
            but once i connect the lvds cable from panel to main boardit goes on and off, despite the u ribbon cables disconnected
            • Diah
              • Feb 2013
              • 6501
              post very clear close and focused photo on this area
              • marillo
                • Sep 2024
                • 28
                thats the left side Click image for larger version
ID:	3463904 Click image for larger version
ID:	3463903 Click image for larger version
ID:	3463902 Click image for larger version
                • marillo
                  • Sep 2024
                  • 28
                  the middle panel board Click image for larger version
ID:	3463907 Click image for larger version
ID:	3463908 Click image for larger version
ID:	3463909 Click image for larger version
                  • marillo
                    • Sep 2024
                    • 28
                    right panel board Click image for larger version
ID:	3463913 Click image for larger version
ID:	3463914 Click image for larger version
ID:	3463915 Click image for larger version
                    • Diah
                      • Feb 2013
                      • 6501
                      Man, not all,,, just one are now important this part... still i cant read the label of the parts, focus it with light. ( ich brauche nur diese Teile um Ihre Label zulassen )
                      • marillo
                        • Sep 2024
                        • 28
                        ah here we go... sorry i thought you need all
                        • marillo
                          • Sep 2024
                          • 28
                          here a better quality one
                          • Diah
                            • Feb 2013
                            • 6501
                            okay, now you disconnect the LVDS , and keep the U ribbon at this time all disconnected
                            first test with yours DM in Diode mode the MOSFET Q001, between the middle and A G
                            with OHM test C 621
                            with diode mode test D007 D008 ( between the three 123 against 456 and in reserve way
                            • lotas
                              • Jan 2016
                              • 4813
                              • Russia
                              Install the jumper first, then experiment with U-loops.
                              • marillo
                                • Sep 2024
                                • 28
                                i will upload some videos tomorrow... i measured everything today and recorded it. i hope i did it correctly, just dont laugh at me please... also i dont know how to interpret the readings... so i hope you csn help me with these results
                                • marillo
                                  • Sep 2024
                                  • 28
                                  Q001: https://www.dropbox.com/scl/fi/ftpd4...nbn5aw6c0&dl=0
                                  c621: https://www.dropbox.com/scl/fi/af9o7...d40bqlg9y&dl=0
                                  D007 & D008: https://www.dropbox.com/scl/fi/pqosr...6udag44zk&dl=0
                                  i hope you can read something from these videos...
                                  • Diah
                                    • Feb 2013
                                    • 6501
                                    lift the 2 LEGS carefully from the board , put all cable back in place and turn on see if there are no boot loop, if no more reboot test in diode mode the Q again and compare to yours first reading
                                    • marillo
                                      • Sep 2024
                                      • 28
                                      you mean with a soldering device to remove the two legs?
                                      • Diah
                                        • Feb 2013
                                        • 6501
                                        lol no with finger nail...lol.... of course u need soldering
                                          Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                                          This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                          09-07-2024, 12:10 AM
                                          09-07-2024, 05:50 AM
                                        • DennisKal
                                          Samsung QLED QN55Q80RAFXZA - No backlights
                                          by DennisKal
                                          Hi, I am working on a 2020 Samsung QLED QN55Q80RAFXZA Version FA02. On Christmas Day, the TV made an odd sound while off (in standby). After that it would not turn on. There was no red standby light.
                                          Based on what I read on the net, I ordered and replaced the Power Board, the Main Board and the LED Driver board with a kit from TVPartsToday. After these were installed, the TV would start up and play the startup tone but the screen was still dark. By shining a flashlight onto the screen, I could see the faint image that was on the screen as it was in the startup mode looking for...
                                          01-05-2023, 07:04 PM
                                        • max789
                                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                          by max789
                                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                          I made the following tests:
                                          1. Disconnected the main board from Power Board = backlight works.
                                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                                          So I ordered a main board from Ebay also BN41-02156A but from...
                                          01-18-2024, 06:56 AM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
