LG 50PA650T Plasma- Help required :)
  • George266
    • Apr 2014
    • 12
    • United Kingdom
    Hi all. I have got LG 50PA650T Plasma TV , but i am somehow stuck
    The plasma does turn on (relay click) but turns OFF after about 4 seconds ( another relay click) . I ca hear Y-Sus board buzzing but NO image at all , JUST audio. Then I have disconnected both buffers and the result was exactly same.
    Voltages:
    VS 1.1V
    VA 3.4V
    M5V 5.2V
    Just to make sure the power supply is okay I have unplugged the Ysus and connected 100W bulb into VS output a the bulb did light up bright.
    So I said, Okay bad Ysus and went on EBay and bought one.
    I have installed the new Ysus and plugged ALL connectors into it. Same result, no picture-just Buzz and audio (..money for new ysus wasted?)
    SOME MORE MEASUREMENTS- Ysus disconnected :
    VS 205V
    VA 52-55V (fluctuate)
    M5V 5.18V
    M-on 3.30V
    RL-ON 2.53V
    STB 5.23V /3.47V when OFF
    5.2 5.2V
    Err Detect 0.6V
    Input board red LED- ON (off when Ysyus plugged in)
    Controll board green LED flash sequence : medium-medium-long-short (off when Ysus plugged in)
    No bulged capacitors, oll fuses OK.
    Anyone can help what should I check next?
    Note: I am not professional I am just trying to learn because I just like to fix things-and reuse them.
    Re: LG 50PA650T Plasma- Help required
    Loud buzz? Too loud for actual watching?
    Check panel for chips, cracks and other damage.
    https://www.youtube.com/watch?v=-iAm...s&noredirect=1
    • George266
      • Apr 2014
      • 12
      • United Kingdom
      Thanks Tom. The Buzz is not as loud as the one on the video -but in quiet room with volume muted it would be noticeable if not annoying. Thing is, the ysus makes buzzing noise even when the buffers are disconnected.. But I will check the screen for cracks too
        Try with just one buffer at a time.
        If it works with the top out, you most likely have a bad plasma panel due to an LG design flaw. The plastic frame around the TV eats into the ribbons, which damages the buffer board. I had exactly the same model, couldn't fix it.
        • George266
          • Apr 2014
          • 12
          • United Kingdom
          I have just checked the panel, there are no cracks. Just wondering is there any way to check if the Ysus is okay?
          Just thinking -could bad buffer damage the newly installed Ysus?
          But as you said- it could be the ribbon cable. I have read your your post where you have mentioned it . Actually, the VS voltage is nearly 0V with ysus connected , buffers disconnected -therefore bad Plasma panel shouldn't affect it as there is no connection between ysus and panel ?
            Ah - missed that. 0V on Vs with Y-sus in? That's a dead Y-sus there... Try checking it for shorts & then order another one... I bet the seller never tested it.
            • George266
              • Apr 2014
              • 12
              • United Kingdom
              Which components on Ysus do you usually check for shorts Tom ?
                Any of the devices mounted on the heatsinks.
                • George266
                  • Apr 2014
                  • 12
                  • United Kingdom
                  Now after I have replaced the YSUS the second time (after the first seller from Ebay send me a faulty one) and I am finally getting the right voltage on the resistors VY=189.3 VSC=159.6
                  Hoverer, when I plug the bottom buffer into the YSUS -->the both VY and VSC voltages drops to nearly 0V .The results are same when I unplug the ribbons which are going to the panel .
                  Voltages are fine when only the top buffer is connected.
                  This leads me into conclusion that the bottom buffer is shorted. Now after I have been reading tom's66 comments about ''The frame around the TV eats into the ribbons'' design flaw, I have tested the ribbons for short against the frame and i didn't find any shorts.
                  Is there anything else I should test before ordering a new buffer -->and maybe ending up with unfixable Plasma which has the ''eaten ribbon issue'' ?
                  Also do you normally replace both buffers even if the top one isn't shorting the YSUS?
                    Unfortunately I was slightly wrong there - the frame eats into the ribbons causing open circuits not shorts.
                    However, the ultimate failure is the same - bad buffer board, dead panel.
                    You need to inspect the ribbons carefully, the hole/break can be almost invisible.
                    • George266
                      • Apr 2014
                      • 12
                      • United Kingdom
                      I have just disassembled the panel and I have found some suspicious damage. Here are the pictures:
                      • George266
                        • Apr 2014
                        • 12
                        • United Kingdom
                        • George266
                          • Apr 2014
                          • 12
                          • United Kingdom
                          • George266
                            • Apr 2014
                            • 12
                            • United Kingdom
                            It is hard to get really close image with standard camera but actual top plastic layer is broken and the conductive part of the ribbon is exposed. The only thing which baffles me is:
                            1.) why the bottom buffer died when the damaged ribbon is connected to the top one..
                            2.) Why I am not getting image at least on part of the screen?
                            Any Ideas?
                              Exactly the same I had. I'll upload a picture shortly.
                                I think you will find ribbon defect lines up with the screw mounts or plastic nibs. They seem to eat into the ribbons on these.
                                That must be 5th LG 2012 series 50" FHD with this problem. (50PA5500, 50PA650T, 50PM670T)
                                • George266
                                  • Apr 2014
                                  • 12
                                  • United Kingdom
                                  It is very difficult to actually see if the conductive part broken, even if I put LED torch behind the ribbon i Can't actually see the breakage. The conductive part is definitely exposed as the top layer bubbled and rubbed through. I believe this happen when you grab and squeeze the screen by palms when moving etc..
                                  I am still tempted to get a new buffer as I can't see the conductivity breakage yet ..
                                  Eeehm , will have to think about if is it worth the risku buying the part.
                                  Tom , if you still have the panel disassembled would you be possible to test it with torch light to see if the snapped lines are visible?
                                    I have since gotten rid of this TV unfortunately. Simply bending the ribbon back showed the break easily.
                                    • thuss
                                      • Jul 2012
                                      • 321
                                      Hi
                                      Could do with some advice. I'm trying to repair my mates lg 50PM670T (which I believe Tom66 you mentioned has a panel design fault). We removed the top buffer tv did not come on.We removed the bottom buffer and we got some activity in the top section and the vy voltages etc came back. So he ordered a bottom replacement buffer board.
                                      We replaced the bottom buffer board the tv came on however theres a 2mm black horizontal line between the two bottom buffer chips. We switched tv off and tried to reseat the ribbon several times but the line would not go.
                                      Eventually we were back at square one ie with no image. I think its a bad panel but could it be a bad buffer I cant see any damage to the panel ribbons.
                                      Any help would be appreciated
                                      • Truncatedhose
                                        Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                                        by Truncatedhose
                                        Greetings all!
                                        Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                                        Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                                        07-04-2018, 10:59 AM
                                      • PlasMatt
                                        LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                        by PlasMatt
                                        I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                        09-20-2025, 06:50 PM
                                      • ArMaaN376
                                        Samsung PS51E550 Plasma TV
                                        by ArMaaN376
                                        I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                        Opened TV cover & observed foll
                                        a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                        b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                        c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                        How to confirm Y -Buffer board...
                                        06-19-2024, 04:05 AM
                                      • Salvatore057
                                        plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
                                        by Salvatore057
                                        I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
                                        Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
                                        I am lost, should I change the YSUS board? Is the YSUS board damaging...
                                        04-29-2018, 01:29 PM
                                      • jm1234
                                        Panasonic plasma TX-P42ST50 - 6 blinks
                                        by jm1234
                                        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                        I checked that board for any obvious faults...
                                        05-22-2024, 06:59 AM
