SOS7 software update for Panasonic 42PZ70 wanted.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    As above, This update prevents failure of the SC board apparently....
    Anyone have a copy around?
    TELEFIX
  • eclectric
    Sony Bravia KDL-70W850B T-CON board / software update issue
    by eclectric
    Hi, I'm hoping someone can help me with this issue before I give up on this TV.
    In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
    Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
    I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
    05-23-2022, 01:25 AM
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
  • sigmeyer
    Need a firmware update software for grundig gbj-9146
    by sigmeyer
    I have a customer complaining that tv has a software issue .. He tried to update with some other software but first he had issue of no picture , then after another update he had no sound but had picture. So its pretty clear its a software problem.
    So im trying to help him out and find him the update software
    TV in question:
    Grundig new york 46 3d WEB((GBJ 91 - 46))
    Panel - LTA460HQ08 // 056D46-SS10
    I have found a softwareupdate_gbj7246.zip file online , but obviously is not the same , it is for the same panel but not the same model ..i cant even download it...
    03-10-2021, 04:16 PM
  • Stephen
    A1706 Critical Software update. Not Touchbar etc.
    by Stephen
    Computer boots and gets the software update. No visible water damage. All connections tested on another logic board and they all work. The logic board only gives this error when booting normally. Boots fine in safe mode. None the less still looking for visual damage and nothing shows damaged on the board. Board has everything disconnected except the USB C and battery so it can boot normally. Plugged up to external monitor. Boot into safe mode and I'm now trying to install Combo update and see if that works, if not any suggestions? I also checked the Wiki Critical Software update page and followed...
    06-15-2021, 12:06 PM
  • Russ17
    SONY KD-43X8305C - Not booting after software update
    by Russ17
    I have been given a SONY KD-43X8305C Android based 43" 4K TV.
    It received a software update which failed and then failed to boot after.
    I have tried holding Power and Volume down (-) then applying AC power, multiple times, with no success.
    The backlight is off, the main status LED is Off, the Mainboard heat sink gets slightly warm if left on for more than 30 minutes, showing it is getting power.
    PSU has normal outputs. Screen appears blank even with a torch test and no start up sound from Android is heard when powered on.
    10-23-2021, 02:41 PM
