Hannspree JT02-37U1-000G Hard to power up
  • splitcrete
    • Dec 2012
    • 387
    • usa
    I have a Hannspree JT02-37U1-000G waiting for me to buy for $25.00 USD. The guy said it takes 10 - 20 tries to power on . I am thinking psu caps. My problem right now is that I have never heard of Hannspree. Parts for this are far and few in between. Is it worth $25.00 or should I move on to a different maker?
    Thanks for any advice.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5086
    • New Zealand
    Re: Hannspree JT02-37U1-000G Hard to power up
    No idea but you could always resell it if you can't get it working
    -David VanHorn
    • truep
      • Aug 2010
      • 373
      It's an off brand, but that isn't always bad! For $25 I would go for it as it's probably bad caps in the power supply. When you take the back off you will probably find one or more bad caps Bulged on top. Replace all the caps on the "cold side" Usually 10-35V with the same (or higher voltage if they will fit) Panasonic FM or FC seris caps you can get at Digikey. I fixed my LG with the same symptom and a couple others that way.
      • DJ_MIX
        • May 2005
        • 118
        I have a old 17" lcd monitor made by Hannspree, sucker works great..
        Only problem I have with it is burn in image at top of lcd..
        Besides that been very reliable
        • splitcrete
          • Dec 2012
          • 387
          • usa
          Going to pick it up in an hour. Your right $25.00
          I blow that on toys every week for my grand son.
          I will post tear down to final fix .
          • splitcrete
            • Dec 2012
            • 387
            • usa
            Well I bought the TV and it was caps . (2) (1500uf-- 16v) , and (1) --(220uf--35v) I replaced them with Panasonic FC series , and the set powered right up. No brain work involved. I did apply heat sink paste to the heat sink covers that screw on. Don't know if that will help transfer heat to the covers better,but won't hurt. This set is built like a pizza oven not much ventilation . Some pics of the set and boards.
            • truep
              • Aug 2010
              • 373
              Just to be safe, I would replace ALL the caps on that side of the board.
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                I tend to replace most--if not all the caps on a lot of PSU's Especially the little 1-47uF ones on the HOT/Primary side--the start-up type caps, only cheap and easy with it all apart.
                Some of these sets run just so hot, its no surprise they pop off with bulgers and dried out caps....
                I did a Bush/Polaroid/Whatever-make set yesterday, with a well dried out main smoothing cap--the 150uF 450V--don't often see those dried out, didn't have a 150uF so it got a 220uF 450v instead, plus a couple of small ones....
                I suspect the set is used from a generator--It belongs to some Travellers....
                TELEFIX
                • splitcrete
                  • Dec 2012
                  • 387
                  • usa
                  I used what I had on hand,but I ordered all the caps on that board. I will change them out when they arrive. Will take more pictures of the NASA HEAT shield that covers the boards when finished.
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    09-06-2024, 05:59 AM
                    HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                    This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-12-2024, 02:15 PM
