What causes tv shadowing ?
  • tmlfan
    • Jun 2011
    • 109
    I found a tv on the local BST someone is selling for 200 Bux, tv is a 65' Samsung un65mu6300, I was told by the person that had it listed that "TV works fine but there is some shadowing in light screens. Hardly notice it but hubby is OCD & we bought a new one"
    Could this be easily fixable as in settings or such or should I just leave it there
  • EazyBone
    • Jun 2023
    • 1350
    • United states
    Do not buy it. Shadowing is caused by bad LEDs. This isn't a edgelit TV and the LEDs can eventually just shut off giving you no picture. It could happen in 20 minutes or 6 months. Eventually they are all going to die. A proper price for this TV would be about 20-50$. If you could fix it, which I probably wouldn't recommend a beginner to do as you have to take the whole screen off and .. lots more problems can occur as well. the parts are probably $50.
    This TV with out bad LEDs is worth like 200-260$
    • Pipolups
      Corsair K70 LUX RGB dying LEDs
      by Pipolups
      Hi there !
      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
      10-08-2024, 11:58 AM
    • THE GTC
      Insignia NS-37D20SNA14 intermittent LEDs
      by THE GTC
      So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
      When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
      11-03-2020, 02:40 AM
    • VitalComputing
      Replacing Mode Indicator LEDs
      by VitalComputing
      I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
      I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
      I thought I could just put a resistor...
      09-17-2023, 04:43 PM
    • jimbofz
      just a quick question do all qled leds appear blue when fault finding ?
      by jimbofz
      i have replaced many leds strips that have changed blue when they are worn
      and the new replacements are perfect white
      but when fault finding do quantum leds always look blue?
      08-28-2024, 06:51 AM
    • Quantum IC
      LEDs for TV Backligth
      by Quantum IC
      Hello everyone
      I'm new to LED strip LED replacement.
      The original LED comes with a single internal LED or chip. I only get at the moment LEDs with two internal LEDs or chips.
      I understand that this is due to the tone of the light they emit.
      My Doubt is:
      Can I use the LED with two internal chips without problem?
      Will there be much difference in the picture?
      I'm going to replace all the LEDs.
      Both LEDs (original and replacement) are 3V and the same size....
      03-04-2022, 04:03 PM
