TEAC LEDV32U83HDR(takes awhile to come out of standby)
  • Amraks
    • Nov 2011
    • 725
    You plug it in when cold you get the red light, you try to turn it on with remote or button it fails to turn on. So 5 mins later you come back and turn it on it starts like nothing ever happened.
    Now I have pictures of the PSU board but they aren't from this tv this is a photo I have found on ebay of the same board. The one in the photo is a refurbished.
    there is 2 capacitors they look like they have replaced in this photo that are a different color to the capacitors on the tv I am repairing they are aishi's..
    I see a lack of grey glue on them.
    I am wondering if these capacitors are the culprits. before I go pouring a customers money into replacing capacitors.
    I have also included a schematic to ZD-95-MP123T-12N PSU for reference.
    I believe the caps are located on the schematic at EC25
    and EC27.
  • Amraks
    • Nov 2011
    • 725
    Re: TEAC LEDV32U83HDR(takes awhile to come out of standby)
    Any idea's anyone?
      Have you checked the power board voltages? You can rule in or out a power board fault by doing that.
      • Amraks
        • Nov 2011
        • 725
        When I turn it on you can hear a high pitch buzz then it comes right..
        trying to listen to fix this tv but my family is on school holidays...
        • Amraks
          • Nov 2011
          • 725
          removed
          • mmartell
            • Oct 2013
            • 3189
            Trouble cold starting ? Take a hair dryer to it.
            • Amraks
              • Nov 2011
              • 725
              will do that I will let it cool for awhile, I have it starting up. I forgot to plug in some plugs.
              I disconnected plugs to get the back off as the cd player is attached to the shell how annoying is that.
              Owner has told me it takes awhile for it to come out of standby when cold.
              • Amraks
                • Nov 2011
                • 725
                voltages are normal I just tested them.
                I am thinking a capacitor problem now.
                as when you turn power off you can still hear a whine..
                • Amraks
                  • Nov 2011
                  • 725
                  Also like to add step by step problem.
                  1. AC power on at the switch you can hear the whine.
                  2. turn on tv with button or remote on the side.
                  3. Red light goes green.
                  4. takes 10 seconds for screen to come on with the high pitch whine stopping once it comes on.
                  this is weird.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    heat the psu board up with a hair dryer for 3 to four minutes does the set switch on any quicker? if so i would check the capacitors with a esr meter.
                    i have a few months old hitachi led set it takes 10 seconds dead on to get picture so this 10 second delay may be normal.
                    • Amraks
                      • Nov 2011
                      • 725
                      yeah but does it have a high pitch whine in standby? I don't think its normal at all.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        none at all on this hitachi can you narrow down the noise at all? maybe a transformer buzz etc.
                        maybe use a long cardboard kitchen roll insert and put one end on your ear and move the other end around the psu you might hear it narrow it down? not sure if it will work i would try it myself.
                        • truep
                          • Aug 2010
                          • 373
                          IMOH, 10 seconds is normal for most TV's I own (for turn on). I cant explain the noise though.
                          • Amraks
                            • Nov 2011
                            • 725
                            none at all can you narrow down the noise i use a cardboard kitchen roll tube place one end on psu board one on your ear you can easily find the noise its just curing it!!
                            Yeah gotta wait for the glad wrap or foil to run out first lol. I did have one of them tubes but the gf threw it out.
                            I will check the caps with a ESR meter, I am still waiting on a soldering Iron handle for station and I am not using my cheap iron on this tv.
                            • Amraks
                              • Nov 2011
                              • 725
                              The whine is coming from the transformer.
                              Have tested them 2 caps I suspected but my tester said they where they are meant to be.
                              25v 1000uf
                              1. 1001uf
                              2 994uf
                              I have tested the voltages they are all good.
                              its just in standby mode its making this noise.
                              I am at a stand still where the problem lays with this tv.
                              I have also tried to recreate the tv not turning on as its turning on normal.
                              Its just a high pitch buzz I am trying rectify
                              • Amraks
                                • Nov 2011
                                • 725
                                I can describe that buzz noise now when I turn off the tv it sounds like a old flash on a camera charging up.
                                • Amraks
                                  • Nov 2011
                                  • 725
                                  just realised I need a ESR meter not a capacitance tester.
                                  Would it be worth just recapping the whole board?
                                  • Amraks
                                    • Nov 2011
                                    • 725
                                    just done a recap on the entire board.
                                    No success its still making this high pitch camera flash noise.
                                    could it be the big caps causing this.
                                    • Amraks
                                      • Nov 2011
                                      • 725
                                      I have gone over my voltages again.
                                      12v = 6.2 mv
                                      12v = 6.2 mv
                                      gnd = 0
                                      gnd = 0
                                      gnd = 0
                                      5v = 9.9 mv
                                      5v = 9.9 mv
                                      5v sb= 5.259v
                                      s/o = 0
                                      5v = 9.9 mv
                                      5v = 9.9 mv
                                      gnd = 0
                                      gnd = 0
                                      not sure if them circuits with the millivolt's on them are meant to be presenting anything.
                                      • Amraks
                                        • Nov 2011
                                        • 725
                                        Just tested conn 3A
                                        24v = 3.8 mv
                                        24v = 3.8 mv
                                        5v sb = 3.6 mv
                                        5v sb = 3.6 mv
                                        gnd = 0
                                        gnd = 0
                                        gnd = 0
                                        gnd = 0
                                        isn't the 5v rail meant to be producing 5v in standby?
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • Crystaleyes
                                          Samsung BN44-00259A standby question
                                          by Crystaleyes
                                          Hi all.
                                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                          08-11-2023, 05:15 AM
                                        • psssst
                                          Yamaha TSX 120 Standby Problem
                                          by psssst
                                          Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                          03-01-2024, 07:25 AM
                                        • reessi
                                          JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                                          by reessi
                                          I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                                          You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                                          Years ago it had some bulging caps...
                                          04-26-2021, 11:42 AM
