picture is all red ish and image stays in the back ground
sony kdl-40cx523
Tags: None
Re: sony kdl-40cx523
Depends on what you can do. OK with soldering a 48 pin, 0.6mm pitch IC? (That's the gamma IC.) Tab bonds on 40" panels have often been tricky for me.
On badcaps this week: we've had 6 failures of AS15 gamma IC...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Up load using file attachment to show us the good clear pictures of the back side of the TV so we see the T-CON board.
Your TV may use this one but we do not know until we see the pictures of your board.
http://flattvparts.co.uk/sony-kdl-40...pe6-35-d057146Last edited by budm; 07-31-2014, 10:55 AM.Never stop learning
Pictures in post 6 is not the picture of the T-CON unless this TV has the integrated T-CON, that is why we need to see the back side of your TV. See post 7 of what T-con board looks like for the model of your TV, there may be more than one version of your TV. It is hard for us to fix TV from remote, so good pictures are required so we can see what we are dealing with and how all the boards are connected together.Last edited by budm; 07-31-2014, 11:23 AM.Never stop learning
So you have one of those LCD panel with integrated T-CON then. You can see the Voltage test points for the GAMMA Voltage VGMA 1~18, take the DC voltage readings with ref to the chassis and list the readings so we can see what they are.Never stop learning
by rimwallThis TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or... -
by NSkyLabI though I've seen all possible kinds of failures but this one is new...
Colors saturation is gradual.y fading out on the left side of the screen (all colors are fading out). While B&W image is looking good.
I tried replacing TCon but nothing changed. So this is looking like the panel failure. Is there a chance it can be fixed?
Any useful measured can be done on the panel's narrow pcbs? Is there may be something similar to taping trick to fix this issue?... -
by domixHello,
at tv KD - 65XF9005 i have a problem.
Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
is this a common problem for this tv?
i attached pictures of inside. Supply board looks okey, no blowed caps.... -
This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 02:20 PM
by DreamcazmanHi all, I recently picked up a Sony KV-XJ29M31 CRT TV (BG3R chassis, Australian model) cheaply & completed the RGB mux mod on it for some retro gaming. That worked great, however, I have another problem which I hope someone can help me with or at least steer me in the right direction.
Basically, the issue is when it's cold, it takes a while (like 2 mins) for the picture to come up. I think the image is there, it's just very dark or dim. I can hear the degaussing sound & I can change inputs & hear audio but no image.
Once it's running properly, it keeps... - Loading...
