Panasonic 42" plasma screen TH-42PZ82BA cheap fix?
  • ajshoe
    ajshoe
    • Dec 2012
    • 477
    • usa
    Re: Panasonic 42" plasma screen TH-42PZ82BA cheap fix?
    need to take better pics
    • tw2005
      • Oct 2011
      • 6458
      Originally posted by DavyMac
      Ok cheers will try and measure later however when I switch on the TV I get these small green LEDs appear on each board then they gradually get fainter then disappear is this normal?
      The SC board will be to the left hand side looking at it from the rear?
      not for a working tv, when they go faint, usually the TV has shutdown and the voltage bleeds off.
      • DavyMac
        • Apr 2014
        • 35
        • Scotland
        Any ideas what to check to see if it's getting voltage to the right places?
        • tw2005
          • Oct 2011
          • 6458
          ? what's the current status of the TV? Is it still intermittent 7 blink? will it stay on?
          • DavyMac
            • Apr 2014
            • 35
            • Scotland
            Still the 7 blinks cant get it to switch on
            • tw2005
              • Oct 2011
              • 6458
              Pity, was hoping she'd still fire up. Only thing i can think of is to see if the SC board on its own is triggering SOS7.
              I've taken this out of a HD 2008 guide.page 15. Should still be able to be applied to this as I see no SC50 jumper connector the later boards have 2009 on to do the same test.
              Disconnect connectors SC41/SU41, SC42/SD42, SC46/SD46,
              jumper between “VF Ground” (labeled H.V. DANGER) on the SU board or SD board and coil L801 on the SC board,
              Power on and see if SOS7 or normal startup with no SOS
              • DavyMac
                • Apr 2014
                • 35
                • Scotland
                #27
                Hmm time to re-start this thread, Not done anything with the TV since last year and managed to get a working&tested SC board for £8 hopefully should clear the fault,
                • tw2005
                  • Oct 2011
                  • 6458
                  Interesting skit, from an Aussie forum too.
                  getting your fair share of fun from this one it seems.
                  • DavyMac
                    • Apr 2014
                    • 35
                    • Scotland
                    #29
                    Looks like I've dropped a clanger and ordered the SC board for the TH-42PZ80B instead of the TH-42PZ80BA the correct board I should have ordered was the TNP A4657 instead I've got the TNP A4410 both look very similar and have the same mounting positions/pins and cable/ribbon connections would gthis work or not worth the gamble?
                      I believe they're compatible - one is a cost-down version of the other.
                      • DavyMac
                        • Apr 2014
                        • 35
                        • Scotland
                        #31
                        Cheers will give it a go, As I've now wired it back up without trying the new board the TV comes on to a red light then will power up using the remote but screen is black/no picture green light blinks very rapidly when you use the remote
                          Check LVDS cable is fully seated.
                          • DavyMac
                            • Apr 2014
                            • 35
                            • Scotland
                            #33
                            Which one is that?
                              Runs between A & D boards, it's a red one, multi wires very thin and delicate.
                              • DavyMac
                                • Apr 2014
                                • 35
                                • Scotland
                                #35
                                Is this it?
                                  That's the one.
                                  • DavyMac
                                    • Apr 2014
                                    • 35
                                    • Scotland
                                    #37
                                    Swapped the lead out with the other I had then started getting the 6 red lights flashing swapped the old D board and lead back across and still getting 6 red lights flashing
                                      Check white ribbon to SC & power to SC are properly connected. 6 blinks is SOS6 (SC Energy Recovery) and could be bad SC board. Does LED on SC glow?
                                      • DavyMac
                                        • Apr 2014
                                        • 35
                                        • Scotland
                                        #39
                                        Finally swapped over the SC board for another which I'd picked up now the problem is the green light blinks loads then comes on but TV won't power up/fans dont kick in any ideas?
                                        • DavyMac
                                          • Apr 2014
                                          • 35
                                          • Scotland
                                          #40
                                          bump
                                          • Lintesir
                                            Panasonic P42S30 Plasma - Pink sparkles
                                            by Lintesir
                                            My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                                            There is about a 5cm high region at the top without any sparkles,...
                                            07-26-2024, 03:16 AM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
                                          • Zelek11
                                            Panasonic Plasma screen interference on left half of screen
                                            by Zelek11
                                            My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                                            This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                                            10-14-2022, 04:54 PM
                                          • renech
                                            panasonic TH-42PC77U plasma television half screen problem
                                            by renech
                                            hello,
                                            I hope someone on this forum can assist me.
                                            I have a panasonic TH-42PC77U plasma television.
                                            the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                                            i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                                            I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                                            I have read some posts that suggest the problem is related to the boards on the left...
                                            12-12-2022, 06:53 PM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
