help with samsung pn58b550 plasma
    Re: help with samsung pn58b550 plasma
    That marks the adjustment point, but we're still looking for a place to test it. Since 3-4 jumper did not work, it is unlikely to be a main board fault.
    Think I should just go with gettn a new y main?
      It's your money, could still be bad control board or bad buffer.
        well im stuck here, and I don't know what to do, if it was a bad buffer wouldn't I have gotten some sort of picture as I was disconnecting buffers and scan drives?
          Not always. Depends on the TV. I have some which do and some which don't. Hence why I wanted you to get all those readings I asked for. The readings so far indicate a good part of the Y-main board is working.
            Ok what other readings do u want?
              They are in the photo I linked previously, between those pins on the buffer board, and at the tab of that SMD transistor....
                sorry tom I didn't even see that smd transistor in the picture yesterday, and whats crazy is that area where that is I took a picture of just now cause that's where I smelled something hot burning yesterday, how do I test that thing? what mode etc?
                  Red probe on point indicated, black on chassis, DC volts, board installed & TV running.
                    tom the voltages bounce from high to low, goes to 14, to 60, 10, 50, 100, 14, constantly just bouncing, and while I was down there, something is real hot burning smell, seems like it comes from that blackish resistor but this smd
                      OK, now pull the buffers out. Does the voltage stabilise?
                      Seems like bad buffer might be pulling down Vscan voltage.
                        I disconnected buffers and scan drive below it, and it still does that, this resistor is so hot my probe touched it and it started to melt and this was about 2 secs after I turned tv on
                          im not trying to be on a component repair for the board, I just wanna replace the board, im just trying to narrow the bad board down
                            Could you highlight this resistor for me on an image of the board... need to see if it might be damaged by a bad buffer board hence causing your fault.
                              its that blackish grey one
                                OK those do feed the buffers. Since you indicate you want a board swap I'd advise swapping both boards.
                                  well tom as I said the y sus still does this without the buffers and scan drives
                                    are u saying change the y sus and y buffers?
                                      Yes, both. Buffer failure might have damaged Y-main.
